2010 SX-450 Head Shake
I have a 2010 SX-450...7.6 rear spring, forks in stock position in triple clamps, 10cc more oil in each fork leg...At the end of fast straights I'm expierencing major head shake...I was told this was due to improper sag and I went from 110 to 112mm...Still have head shake...This is my 1st KTM, do I need a stabilzer? Any advise?
I'm 195 pounds without gear...Forks were bottoming HARD over big doubles and flat landings is why I added oil to the forks...I turned in the clickers on the forks and they were harsh in the mid-stroke, after adding oil I went back to the stock compression setting and they seem fine now. I'm a Vet B rider if that helps.
