Hour meter virgin, install question
Feel stupid asking but I have never installed an hour meter, and I'm an electrical retard :bonk:. I got this one from ebay which I'm sure some of you must run
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250678132241&viewitem=&sspagename=STRK:MEWNX:IT#ht_842wt_1165
So I hooked up the ground wire underneath one of the bolts that holds the airbox to the frame. and wrapped the black wire around the spark plug cap a few times. Is that correct to just wrap the black wire around the cap?
then I tried kicking the bike over and the meter didnt respond
That sounds like it's correct. Maybe just wrap around the plug a few more times.
I doubt the plug goign off a time or three will show any time on the meter. Mine brakes things down to the 1/10" hour so you would need to kick it for 6 minutes to do anything the meter would show.
Gotcha, thanks guys, ill go for a little ride around the neighborhood when I get home and see if the display pops up
You say you wraped the wire around the "CAP"? . . . It should be wraped around the plug WIRE itself. The meter counts the electrical pulses traving thru the wire and may not pick them up thru the cap.
ok thanks I was curious about this as well, I will wrap it around the wire then and try tonight when I get home.
I've had a few other bikes that I have bought and came with hour meters, and I think they were all wrapped around the cap, but I'll take your work for it.
so I wrapped it aroudn the plug wire this time, and ran teh bike for 7 mins, nada.... either I'm a complete idiot who can rebuild a motor but can't install an hour meter or the unit is faulty. Gunna email the ebay seller right now
most are just 1 wire not sure why there are 2? if used as a ground maybe your location is bad? will aluminum work as a ground as you said you said you mounted to the sub frame??
We receive a lot of inquires about how to install our hour / tach meters, so we made a video going over all the details. Here it is:
Hopefully this helps.
thanks.
...Eric
thanks for the post eric, turns out the unit I orignially got was defective, I have since installed the new one they sent and it works great
