06 525 AC Pump
Hi i bought the Acc Pump from JD i have fitted the ac pump but it is leaking fuel only when you rev the engine
i put the old one back in and that one leaked as well
can anybody help to fix the fuel leak from the acc pump
Do you mean its leaking around the gasket area of the AC pump assy.?
mine has no Gasket just the acc pump and the o ring it only had 1 o ring when i removed
it
there are two o-rings, one is recessed on one side and the other sits on the opposite side- as in one is on the carb body and one is on the AP cover.
thanks guys it was the missing O ring all good now
now hopefully when i take it out this weekend the 1/4 throttle bog has gone
I'm missing the o rings . And mine slowly leaks . Where can I buy new ones ??
My sons 400 is having the same problem. When we took it apart, we only say one. Replaced the one from the dealer and put back together. It still leaks, but less. I plan on going to the HW stare and try to find a set that has a similar size.
smaller of the 2 orings on the ap pump cover has a flat on one side needs to oriented correct.
The seal around accelerator pump continues to leak after a similar second o-ring washer was added. This bike is a 02 400EXC.
I have replaced the diaphragm. The small o-ring washer has been replaced. The parts came from a KTM dealer, but the diaphragm did not have
the metal base as the original. The small o-ring that came from the dealer was not flat on one side as Highmarker as observed. The one that
was in the AC pump, did have a flat side. I thought the flat side was the cause of the leak. Apparently, not. The carb diagram only shows
this Model carb with one o-ring rather than two as some of you have mentioned.
Any suggestion that would lead to stopping this leak would be most appreciated.
59031058000   U-RING ?
Thanks. I looked on the diagram to find that part. I see it is described as an "U"-ring. That is one of the
parts that was replaced. The old part was shaped like an "O" and was flat on one side. It was
replaced with another "O"-ring shaped rubber washer. Seemed to match up. Don't know why they call a "O"
shaped ring a "U"-ring.
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
