07 exc 525 no spark
after breaking my only key last week dont ask , and while im waiting for a new one i figure i should know how to hot wire it . rather than get the wiring diagram before starting i start tying wires together. after blowing the fuse twice i get the manual and its clear how easy it is .
connect bl & br and connect ye-r & wt-r .so now it cranks, and turn sig work but no spark
so what did i fry, CDI, PICK UP , COIL , ANY HELP WILL BE GREATLY APREICIATED
what can i test with out thro in lots of money at it
i have also asked over at ktm talk
Well I also posted this on KTMTalk.
Posted by KevInYorks
This reply is about ignition problems, but I will leave in in for other to use
Resistance checks:
Ignition Coil
Measure Cable colours Resistance
primary coil blue/white � ground 0.30 Ω �15%
secondary coil blue/white � ignition wire 6.30 kΩ �20%
Stator
Ignition Measure cable colours Resistance
Pulser coil red � green 100 Ω� 20 Ω
4K-3B (2004 model but yours will be similar?)
Exciter black/red � red/white 15 Ω� 3 Ω
Charge coil ground � yellow 0.65 Ω � 0.15 Ω
white � yellow 0.16 Ω � 0.03 Ω
Voltage checks
Measuring conditions:
� cold engine
� seat and tank removed
� all connectors and the ground connection in a non-corroding condition, connectors tightly connected
� battery loaded (if installed) and light switch turned off
� the gap between the rotor and pulse generator must be set to 0.75 mm
� compression release lever pulled
� kick the kick starter forcefully at least 5 times for each measurement
Check the pulse generator for an output signal � two-pin connector
with green and red cable colors:
� Apply the red measuring lead to the green cable and the black measuring lead to the red cable, disconnect the CDI unit
Multimeter display: 4.5 volts +/- 0.5 volt
� Same measurement with CDI unit connected
Multimeter display: 3 volts +/- 0.5 volt
Check the generator charging coil for ignition capacitor charge � two-pin
connector with black/red and red/white cable colors :
� Apply the red measuring lead to the black/red cable and the black measuring lead to the red/white cable, disconnect the CDI unit
Multimeter display: 30 volts (35 volts for 400 SX) +/- 5 volts
Multimeter display: 200 volts +/- 10 volts
Check the primary voltage output for ignition coil control for output voltage (blue/white cable color):
� Apply the red measuring lead to the black/white cable (ground) and the black measuring lead to the blue/white cable, CDI unit and ignition coil connected
Yellow wire feeds ac to the lights, white wire charges battery (via regulator/rectifier)
Checking the generator output
� cold engine
Check the generator output for voltage between the following cable colors:
� between yellow and brown (ground), loom disconnected
Multimeter display: 15 volts +/- 1 volt
� same measurement with loom connected
Multimeter display: 12 volts +/- 1 volt
� between white and brown (ground), loom disconnected
Multimeter display: 19 volts +/- 1 volt
Multimeter display: 14 volts +/- 1 volt
NOTE: The black measuring lead of the peak voltage adapter must be
applied to the ground.
Check regulator rectifier output voltage cable colors yellow/red, regulator rectifier bk connected,
capacitor disconnected (if installed) and fuse bm removed:
� between yellow/red and brown (ground)
NOTE:
� The black measuring lead of the peak voltage adapter must be
� For facilitation of work, the regulator rectifier bk can be detached from
the frame.
Checking the voltage regulator-rectifier
A defect voltage regulator can cause different kinds of trouble:
● No voltage in the circuit
In this case, the voltage regulator must be disconnected at idle speed.
The voltage regulator is defect if the power consumers now work
properly.
If the power consumers are still not supplied with power, the switch,
the wiring harness or the ignition system must be checked for defects.
● Excessive voltage in the circuit
The bulbs burn out. In this case the voltage regulator must be
replaced.
Checking the charging voltage
NOTE: The values stated below only apply to fully charged batteries
(minimum charging level 90%).
� Start the engine and switch on the low beam.
� Connect a voltmeter to both battery connections.
� Accelerate the engine to a speed of 5000 rpm and read the voltage.
Nominal value: 14.0 - 15.0 V
In the case of a significant deviation from the nominal value:
� Check the connector between the stator and the voltage regulatorrectifier
and the connector between the voltage regulator-rectifier and
the cable tree.
� Check the stator.
� Replace the voltage regulator-rectifier
Quick tip on your key. Get an extra blank key from the dealer, take your new key and have it reproduced at home depot for cheap. I tried having it done from the original to the keys you buy at Home depot, but it doesn't work.
I bet I know how you broke it...... Did it have to do with your steering lock?
I don't mean to be too radical, but.....
I removed anything that had related to the key activation in my 07 525 EXC the day I bought it brand new. I am not sure how much street riding you do on yours and if you have to leave it unattended in the urban areas, but I figured there is no need for a lock, whether ignition or especially fork anywhere out on the dirt. Is helps to shed off some weight too (the module, heavy housing etc)
Motohouse had helped me to re-wire and replace the key ignition with regular start up button.
As far as hot wire. I am not sure. However if you really get stuck... well, there is a kick starter on it as a part of an "emergency survival kit". It's hard to crank for the first time, but then it gets easier. I didn't really have to use it, I was just trying to test how stubborn it is. If kick starter doesn't help, maybe it's your spark plug?
lmao yea it had to do with the steaing lock
Resistance checks:
Ignition Coil
Stator
Voltage checks
� cold engine
� cold engine
NOTE:
the frame.
properly.
replaced.
the cable tree.
� Check the stator.
thanks again for the tech info i will print this for sure
yea im thinking about going to a toggle switch , but do like the idea of a locked ignition i have some new blanks on order from the ktm dealer will see
I forgot my key at home before so I had to hotwire my 07. Y and W are to energize the starter button so connect them. Bl and br are to ground out the ignition so disconnect them and it will spark.
thanks thats what i figure out eventually, running again :ride:
