06 525 exc leaking oil front sprocket
i had replaced my front and rear sprockets
i cleaned all the crap from the front sprocket installed the new sproket
but now noticed it leaks oil ( behind the front sprocket ) is this a big job
cheers Phil
I'm having the same problem. There are a lot threads on here about it though. Depending on your mechanical skill level, it shouldn't be too bad of a job. I just picked up my 450. The previous owner swapped the sprockets and now it leaks. I'll be doing the repair myself. I'll try to make a DIY article when I'm doing the job, so others can have some instruction. If you figure it out first, let us know.
One thing to watch is some aftermarket front sprockets are too thin and that can cause a leak, the cupped washer needs to preload the sprocket. Also make sure you are not running the chain too tight.
Ed
remove the sprocket, pull out the bushing and clean the inner lip of the seal with a q-tip, buff the bushing with emery cloth, replace the o-ring. The other parts to this are pressure pushing inward to create the seal. So the sprocket has to be the right thickness and the washer has to have its spring tension too. The washer can be "re-cupped" by using a large socket or something with a hole in it to put the washer on. Then hit the washer with a ball peen hammers round end to give it its cup back. May have to hit it a couple of times to get it cupped. Has worked every time for me. No new parts except o-rings and a washer now n then.
Edited by Mike in Fresno
Just an idea, Im assuming your sprockets are worn out, if so you may want to consider changing the counter shaft seal, bushing and bushing o-ring seal, while your at it get a new spring washer (re-cup the old washer and keep as spare), I dont know how many hours you have on your bike, or how and where you ride it, it might be a good idea changing out these parts as preventive maintenance, its not expensive, the job is not hard, but if you have never done it before, you may be a little apprehensive in doing the job, pick up a $10 seal puller to make things easier, if you choose to go this route and get confused, just post it and many will jump in to help.
P.S: I highly recommend using KTM made front sprockets only as suggested by others.
those seals are really hard to pull out...
I bought an o-ring and another piece, i assume its the washer you're all talking about. its a gold ring. I can see the old "washer" but I can't get it to come loose. I pulled out the silver ring that was around the spindle. My oil is draining, but I cannot seem to get that washer loose to replace it. any ideas? (im too cheap to get a seal puller.)
I got it done, it was a pain in the but prying it out, probably better to get the right tool for the job. It wasnt bad after that. Just be careful not to break your chain's master link clip like i did...
too bad you went thru all the trouble cuz it probly didnt need to be replaced, its your money n time tho
it cost me a total of $6 for the seals.
$12 total if you include the price of breaking my master link.
The good thing is, your now familiar with the job, its one of these piss off damned if you do or damned if you dont jobs, but for sanity sakes get a seal puller, the seals out in seconds, some people drill holes and put screws in, but you have to be real carefull, is what I use and it costs $10, it makes the job alot easier, faster and less prone to mistakes.
well I had no idea the seal was so cheap, seems it was 12 or so when I did it once on my 200. Any way, next time remember to just use a qtip and clean it, it will fix it 99% of the time
If you are too cheap to buy a seal puller, you can drill 3 small holes around the seal. Then drive in 3 drywall screws and use them to pull the seal out with the claw end of a hammer.
Make sure you don't drill in too deep or drive the screws in too deep!
does it have a stock KTM part sprocket and did you get a new washer?
I assume its an aftermarket sprocket (it came on the bike), and no, I did not get a new washer. If its the washer's fault, I can do that. I dont want to replace the sprocket though, just to fix a minimal leak.
With one hour on my new bike I changed the front sprocket to a KTM hard parts sprocket with less teeth. It started spraying oil from the shaft behind the front sprocket. Turns out I just need to bend washer to have more pressure on the sprocket and has not leaked since.
Like most that have posted I believe the majority of the time you do not need to replace all of the seals.
It is an odd set up that it needs pressure on the seals so they do not leak oil.
you have the info on what to do, dont be afraid to spend a few dollars to fix what was probly the original problem instead of the seal
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
