Rear wheel for 98 CR125
Hi Guys,
I have a 98 Cr125 and i am trying to find a rear wheel to fit.
After searching I have found conflicting posts about what years are interchangeable.
Can someone tell me what years would fit?
Also once I find a rim how do i tell the year it is from? is there a stamping?
Any help will be appreciated.
Thanks.
www.servicehonda.com
Use the advanced OEM parts lookup
Find the bike by year and model
then find the hub
then click the "where used" button looks like a ?
It will tell you what makes,models and years use the same hubs.
all 125 and 250f bikes use a 1.85 rear rim.
all 250 - 2stroke and 450F use a 2.15 rear rim
They all use a 1.6 front
I'm not sure what I am doing wrong but I cannot see the "where used ?" Button?
I can get an 02 rear rim + axle etc. Will this be a straight fit ? or is it a different size?
I have read they went to a 24mm rear axle in 03 so does this mean it will fit mine?
Thanks.
The wheel I currently have has the followint markings
ML3RR 234
72 - 08 -15
19x185
According to http://**************/HONDACR125BIKEID.aspx
ML3-RR 234 - 20MM AXLE DIA - BRG TO BRG 134MM - BRAKE ROTOR DIA 220MM - ROTOR BOLT CIRCLE DIA 140MM 4 BOLTS - SPROCKET BOLT CIRCLE DIA 153MM 6 BOLTS - FITS 95-99 CR125, 95-99 CR250, 95-01 CR500
It should fit my bike but the axle is too big to fit through the swingarm. It is more like a 25 mm not a 20mm like it should be any ideas?
i have a 95 cr250 wheel on my 99 125 anything above 99 won't fit on the rear.
