3 Turns Out ??????????
I have a 06 CRF 250X I just got running after it had been sitting since March 2008.
Had problems starting & idling
Had the carb cleaned, but still had problems keeping it running, Then flushed the tank to rid if of any dirt & dust. Put an inline fuel filter on too.
I now realize the fuel screw needed to be turned out more BUT the only way I can get it to keep running & idling properly is taking the fuel screw out to 3 tuns out. is this ok?? Or should the jetting be changed?
What recommendations do you have?
Here are the bike specs
06 CRF 250X
JD Jetting Kit
#158 Main Jet
# 42 Pilot Jet
Needle Clip Position is 5th from top
fuel screw 3 turns out
Engine & Performance Mods
Quick shot APC
Air Box Mod
Pink Wire Mod
White Bro E2 W 250 R Header
Smog block off kit
S1 Hot Cam
If the fuel screw is at 3 turns out, use a one size larger pilot jet and try again (I think that would be a 45 PJ).
Your pilot jet is clogged. You probably do not need a larger, just a new one the same size you currently have.
I think you might be right, because it has been sitting so long it's probably clogged :thumbsup:
I hired a mechanic to do a complete carb cleaning, I also flushed and cleaned the tank to make sure it did not keep getting clogged if that was the problem. I also inspected it last night, seams like its clean to me.
Im not so sure its still clogged.
Can you clarify for me the pilot jet is the one way up inside the float bowl? the hardest one to get to.
FrankV are you saying the next jet size from what I have (a 42) is a 45? Dose it not go in single increments?
The pilot jet is the long one, besides the main jet, with the small holes in the side:
It is not always clear whether it is clogged or not (there might just be a film on the inside).
I would get a new 42 and one larger (yes, I believe the next is a 45, it doesn't go in single increments).
Frank Thanks for clearing that up Ill give it a shot.
As far as turns out the original set up on jetting with a 42 was 1 3/4 turns out for fuel screw. Dose this sound right? Also if I do go to a 45 what should the fuel screw be.
thanks frank
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
