CP piston worth the extra $$$ 13.5/1 still pump gas?
Time for a piston in my 08 250 xcfw and here are my choices:
1. CP piston kit, 13.5/1 - $229 shipped
2. JE piston kit, 13.1:1 - $191 shipped
3. Wiseco piston kit, 13.1:1 - $155 shipped
Looking for the best bang for the buck. Also is 13.5:1 still good to go on pump gas?
Yep, you are safe on pump 91-93 up to 13.5:1. Just use a good brand like Sunoco or BP. Let me know if you have any questions.
I ran a JE piston in my bike the first rebuild. One thing I didn't like was that it didn't have the coated skirt. Felt no real difference in power either. Went back to stock last time.
Here is a pic of our 250 SX-F / XC / XCW-F part. Wiseco ArmorGlide skirt coating is permenantly bonded to the piston skirts.
So what did you end up with???
Hey Wiseco guy, why does your catalog list the 450 piston @ 97mm? The bigger of the two spec'd sizes is 96.97mm (OEM). I only ask this because I chose a ProX which has a similar discrepancy except it's smaller (96.94mm). It would seem that with your piston being forged, it would have a greater change in dia as things heat up. Your know how would be appreciated.
Hey why wasn't Chris at the UP300? Had talked to him last year and he was going to hook me up.
Haven't bought anything yet, got 5 months to get it done, no hurry.
It was my year to go to the RM400 instead. Hopefully I'm back on the roster for the UP in 2011!
Ran a JE in my CRF and I did notice a bump in bottom/mid power. Got good life out of it too.
Hey is this Chris? You gave me your card and cell # last year but I never called. Was hoping you would be there this year. It was a blast the trails were freakin awesome! Hope you can make it next year.
Wiseco lists all of our applications by bore size, not piston size, which is why our listing says 97mm. The pistons OD's are sized appropriately to run at the designed clearance for each application. I would have to check with our technical department to say for sure what our actual piston OD is, or you could give us a call and check with our tech support. Hope that helps.
Where are the Wiseco pistons made nowadays?
Thanks ClockworkKTM for the smokin deal on the CP piston kit! :excuseme:
The u.s.
Forged, machined, and skirt coated under one roof in Mentor, OH.
What about the crankshafts?
I think we all know the answer to that.
Actually, I don't. Are they still made where they used to be?
