KTM 520exc top end
I am planning to put a new piston in my 2003 ktm 520exc (yes I know they supposedly didn't make an 03 520 but that is what my vin says). I was thinking about upping the compression...what is the highest compression ratio that you can still run pump gas?
Is there anything else (within a $400 budget) that I should do while I have the cylinder off??? Port and polish? Over bore and run a larger displacement?
I know your question is about performance improvements but you might need to spend some of the budget on updates and maintenance. Your first priority should be to be sure the later motor updates have been done (cam sprocket, screen, etc.). Not expensive but should be done while apart.
Next the intake valves are very soft on the RFS and likely will need to be replaced.
Only then if you have $$ left should you even consider performance upgrades.
Edited by BDM
I don't think you can bore your cyl without getting it renicle and thats more of a pain in the a** than just buying a big bore kit . but I agree with BMD worry about the must dues before the want too's ride hard and fast
I have a 2003 525 and just did a 12.5/1 wossner piston and had djh put in oversize kibblewhite valves and unshroud the valves. Bike runs great on 91 pump gas. If you need to have the cylinder redone, you might as well do a 540 kit. My cylinder was fine so I stayed with the stock bore.
Ok, so it looks like i need a new cam sprocket, and possibly intake valves? Is there any way to tell if the valves need to be replaced? Also, what is the screen you referred to? Sounds like I should run a stock sized piston (95mm) and not run any higher higher than 12.5:1 compression. Anything else I should do while i'm in there?
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the advrider.com writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
