gs500 wheel swap SM
Well here is the poop
First of all it's not the cheap way, i've got a little over 800 bucks in mine
the reason i went this way is because i wanted to keep my enduro
stock wheels to put my knobys on for off road use and i wanted a street
set up for daily rider so in short if you just want a super moto set up
use your stock hubs and get a set of rims and spokes from pro cycle
and lace them up, get the tire's you want and you will get by cheaper
and it is a direct bolt up. plus you can add a 320 mm front rotor kit.
Edited by CDS 1
Looking good man! :thumbsup: So where is the expense? Purchasing the wheels and/or the machining costs?
Looks great! Is there a build thread/pics on these anywhere?
yes there is a thread it is at south bay riders the dude is nepuck but it does not give the whole story rob is doing this mod also and i figured when he got his done he would put up a how to with all the details which he does so well.
any way here's my story
you might be able to get it done cheaper depending on the price of the wheels and the machine work
1. Ebay wheels with shipping
which included all the spacers
rear rotor and crush hub $240.00
2. Machine shop take 6.5mm
off the rear hub on the rotor
side, cut down rear rotor to the
same size as the stock dr rotor
bore out rear spacers to 20mm
so you can use stock axle, bore
front spacers to 17mm as to use
stock front axle. $267.00
3.front rotor ebay 93 gs1100 $20.00
4. new front and rear wheel bearings
from suzuki $100.00
5. remove and install bearings $ My time
6. sand blast and paint rims $ 20.00 did my self
7.cut spacers down to fit and take
material out of the front and rear
calabers so rotors dont rub. $ grinding disc and my time
8. new 520 chain with 14/41 sproket $ $100.00
9. continal road attack 150/rear 120
front. $ $280.00
Total build $ 1027.00
the fun i had doing it Priceless
if you need part numbers let me know and i will post them.
Killer! Thanks!
