Just picked up an '05 230
Hey guys, we just picked up an '05 CRF230 for my Dad yesterday and I figured I'd chime in here to get the low down. Basically looking for any mods, advice, things to look out for, that kind of thing.
A little info on my Dad, he's an old racer that had some skills back in the day, but his time in the saddle now is about 2 rides a year. He's lost a lot of his confidence and doesn't ride very fast. He's been riding a lowered DRZ400, but it's just not working out. He's never felt comfortable on it and it's too heavy, and top heavy, for him. He's 74 now, has one replaced hip and the other just worn out and a bad right knee. It's time for a more simple bike for him so he can just play ride.
The bike we bought is very clean, but I only have an approximation on hours from the guy we bought it from. He's claiming about 20 hours, it looks like that could be legit. He enriched the carb tune, swapped out the skid plate for a Works Connection and put on hand guards, other than that the bike is bone stock all the way down to the original tires. It's had two previous owners that both used it as a Wife's bike, hence the reason it was never ridden. lol!!
My plan of action is new tires and I have to do something with the suspension for my Dad's weight, he's about 240-250 pounds, and I want to get rid of the stock bars. I don't have any other plans unless you guys can tell me some things that really should be done.
I was wondering about bar height, the stock ones seem a bit low, do most people go to a higher bar? They seem OK, but compared to my bikes they look very low.
I was also wondering about the success people are having with just swapping out springs on the suspension. Is it fine if you're not hammering trails or the desert? Or is it necessary to get the valving redone even for low speed easy riding? Since we're making such a big jump in spring rate, I'm a little worried about the suspension valving being too soft. I contacted Hlebo Bros. and it would be $575 to totally rework the front and rear. Is it worth it, or could I get away with just springs?
The only other concern I have is long term enjoyment for my Dad with such a lesser bike than he's had. I know this is a starter bike and the power is limited. With out breaking the bank, is there mods that can be done over time to keep the bike interesting? I know I can get a pipe, and probably a cam, but is there a significant grin factor pay off to the various parts available for the CRF230, or is it just spending money for a little gain.
Thanks for any help.
Sure, you are on the right track with your suspension advice. If you've got the money for it, that would be an awesome addition.
My son bent the handlebars on our 230 in short order, and we installed some $65 ProTaper Cr-Hi rise handlebars. They are a little taller and have less sweep, making the bike less crowded, and a lot more comfortable.
For a 74 year old... just make the bike as comfortable as possible, and don't try to coax him into doing anything too dangerous, as at that age... a person gets hurt a LOT easier, and healing time is forever.
It will be an awesome play bike. I think he'll love it!
You can install stiffer springs into the stock forks, but it might be too much for his wrists. A stiffer spring in the rear will also be too much for the stock shock. For a young kid, I might recommend keeping the suspension all stock, except for one BBR spring in the forks, but for a guy that age, you need to make it plush. Bite the bullet and take it where you have planned. They have an excellent reputation with these bikes.
Good Luck!
I put renthal rc highbend bars on my 230. I also run bbr springs on forks and monoshock. For his weight, he might be ok with the stiffness. I wish you could try it before you install them, but I like mine. If money isnt an issue, have the suspension reworked.
As far as the fun factor, have him ride it and if he needs more power there is a million forums on mods. I installed the factory power up kit and a 14 tooth c/s sprocket and am pretty happy with the bike. I'm pushing 40 and weigh about 220 so I'm a fairly casual rider myself.
check the jetting that has been installed. I've used coeshow's recommended jetting and has really made the bike a blast to ride vs stock vs Honda recommended power up mods.
120 main, stock needle in the 4th clip position, 45 pilot. remove intake snorkel/baffles and exhaust baffle (leave the spark arrestor in).
I use works shocks on both my crfs and emulators in the forks. good start to making the bike a lot easier to ride.
yes, replace those stock, junky tires... they are just plain dangerous.
Thanks for the posts guys.
Did some shopping already. We have new tires and tubes on the way. I got some Maxxis IT's, those should work all around for anywhere this bike will go. I have a left over set of Pro Tapers, so we got a set of adapters, grips and a bar pad coming. The adapters should give us the extra height we need.
I called my suspension guy and it turns out he's familiar with the CRF's and can get it done in a few days. He'll be doing emulators in the front and new springs front and rear. After some ride time, we'll see if he needs to do anything with the rear shock.
We're taking the forks and shock over tomorrow and the parts are on the way, we should have everything by this weekend. :thumbsup:
kkim, I'll dig in to the carb and check it out. I do know it ran better than any other we looked at. I still need to un-plug it though, so might have to make some changes.
The 05 doesn't have clips on the carb's needle. You'll have to use a #4 washer or something to space the needle. If you need to adjust the idle mixture knob on the bottom front of the carb, you'll need a special tool, as it's not a screwdriver slot, it's D-shaped.
I also used the #120 main instead of the #134 that comes with the power-up kits. Works GREAT.
I changed the idle jet, added a washer to the needle, but didn't mess with the idle screw yet.
Changing the stock main (#105, maybe?) for the #120 made the biggest difference.
Good Luck!
I think you have the years mixed up:
CRF230F - Carb info <-- linky
OK, I guess 05 was the last year with the adjustable needle.
Mine is and 06.
Nice catch. :thumbsup:
Well, got my handle bar parts in, and just realized either the previous owner hacked a lot off the end of the throttle tube when he put the hand guards on, or these bikes have short throttle tubes. I can get an OEM tube tomorrow at the dealer, but would like to know if they are a standard grip length. It comes with a grip molded on I'll have to cut off. I've seen after market tubes with no grip and they look long enough for a standard grip, but I'd have to order and wait.
Any one familiar with the stock tube?
Is it long enough for a replacement grip?
Yeah stock throttle tube is full length
however, whatever you do, make sure your throttle tube doesn't stick off the end of the bar!
If you don't run bark busters, when you drop the bike, the throttle tube will jam/break really easy.
I always cut the ends off mine and moved them up the bar about 1/8" that way when I crash they don't get destroyed. Running stock tube on my 150f after 4 years :thumbsup:
at least that's how I do it. Before I did this, I'd ruin a throttle tube fast. Now I have yet to ruin a throttle tube sine I started doing that.
I even purchased a billet one for my crf 50 once, took me two weeks to bend it and have it stick and be ruined!
Cool, thanks. :thumbsup:
I'll just pick up the OEM one tomorrow. It's only $10.68 where the aftermarket's are around $15 or more with shipping and all. Makes a nice change when OEM is cheaper. :blah:
To address your power concerns, there is always more available for those with the $$. Check out Coeshow's bored crf"250". http://www.coeshow.com/_mgxroot/page_10761.html - That thing probably makes more power than the stock crf250 mxer. Food for thought :thumbsup:
Just to update, the stock throttle tube was short. I hollowed out the end and let the excess grip sit over the bar. The after market grip was about 3/8" to 1/2" longer than the tube.
Maybe other years have longer tubes? I don't know, but I got it to work, it's all good. Next time I'll get an after market throttle tube.
  • Similar Content
    • By jmathey9
      I have a 2006 CRF230 with an aftermarket exhaust. I want to bring it back to stock.
    • By Euler Vaz
      I thought about using a 90/90/18 rear tire on the CRF230F to reduce unsprung weight, rotating mass and ground contact in order to optimize motorcycle performance. I use the crf230f for motocross. Do you think it would be a good change?
    • By 230F
      Jetting the 230F
      By: Phil Vieira
      This project takes no less than 2 hours if you have never done jetting to a bike before. It took me 1.5 hours, to take my bike apart, take out the needle, change my pilot jet and the main, and take pictures along the way, but I have seen the inside of my carb 3 times, so I know my way around it pretty well…
      You should be jetting this bike right when you get it home. This bike comes lean from the factory. If you don’t know what that means, it means that the bike is getting too much air, in terms, a hotter engine, and your plugs will get hotter, and a decrease in HP. To make your engine last longer, do this.
      These jetting combos are for a 2000 feet and below scenario. Any altitudes higher, you should do a search on the forum. If it cannot be found, post on the forum. Please don’t post on the forum “How do I do this…” You have all the answers here.
      This project comes to a grand total of less than 30 dollars. The needle is 20, the main jet is about 3 dollars, and the pilot is 5 dollars. You may not need to do the pilot jet depending on your situation, but again, if you’re riding 2000 feet and below, it’s a good idea to get a pilot jet.
      The jets I used consist of a 132 main, 45 pilot and the power up needle with the clip on the 4th position.
      Part numbers:
      16012-KPS-921 – Needle (Includes Power up needle, Clip, and needle jet)
      99113-GHB-XXX0 – Main jet (Where XXX is the size)
      99103-MT2-0XX0 – Pilot jet (Where XX is the size)
      For the Jets, just tell them you need jets for a regular Keihn carb, (also known as a Keihn Long Hex) main jet size XXX, pilot jet size XX. They should know the part numbers. For the needle, bring the number along. If you are lazy, they should have a fiche and they can look up the numbers. Then again you can take in the old jets, and make sure they match up to the new ones.
      Now, the tools you will need are as follows:
      ~A collecting cup of some sort. I used a peanut butter jar.
      ~Ratchets for the following sizes:
      - 6mm, 8mm, 10mm, 12mm
      - Extension for the sockets needed
      ~Phillips and Flathead screwdriver (Be sure these are in perfect condition. A badly worn screwdriver will strip the screws)
      ~Needle nose pliers
      ~”Vise grips” or known as locking pliers (Two)
      ~Open end wrench 7mm and 12mm
      ~ It’s a good idea to have a extra hand around
      (Not needed, but I highly recommend tiny Phillips and flathead screwdrivers (Pictured next to the jar and the ¼” extension) I recommend these for removing a couple things since you can put pressure with your thumb on the end and unscrew it with the other hand. This insures that you will not over tighten any parts, and ensure that you will not strip the heads of the bolts.
      Ok, now that you have the tools, let’s start by putting the bike on a bike stand. I put it on the stand rather than the kickstand because it’s more stable and sits higher. I hate working on my knees. Start by taking the number plates off. Yes, both of them. The right side, you take off one bolt and the top comes off of its rubber grommets, pull the top off, and the plate comes right off. The left hand side, use the 10mm socket to take the battery bolts off, and then take the Phillips bolt near the back. Again, rubber grommets are used to hold the top in place. Take the seat off. There are two mounting bolts on the back:
      Those two bolts are both a 12mm socket. Use the open end wrench on the inside, and use the socket on the outside. You may need to use an extension if you don’t have a deep socket. Once you have the two bolts off, slide the seat back, and lift it up. This is what you have. Notice there is a hook in the middle and a knob on the tank. That is what you are sliding the seat off of.
      Now that the seat is off, you must take the gas tank off. Don’t worry, you won’t spill any gas any where, I promise. On the left hand side of the bike where the valve is, slide down the metal clip holding the tube in place. Turn off the gas supply, and slip the tube off slowly. Now take off the two bolts in the front of the take. This is on the lowest part of the gas tank in the front, behind the tank shrouds. The socket you will use is an 8mm socket. Take the bolts all the way off and set them aside. Now look back at the last picture posted. On the back of the tank, there is a rubber piece connected to the knob and the frame. Slip that rubber piece off of the frame. Pull the vent tube out of the steering stem and lift the tank up. Don’t tip it, and lay the tank aside where you won’t trip on it. This is what you’ll end up with:
      It may be a good idea to take a rag, and wipe all the dirt off the top of the bike if any. You don’t want anything dropping down into the carb. If you do, engine damage is the result. A clean bike is always a good thing! Now we must drain the gas out into that container. This is very easy. Make sure you open the garage door, windows, whatever, to let the fumes out. Breathing this crap is bad. Here is where the drain screw is:
      (Don’t worry about removing the carb, that comes later) This is on the right side of the carb, on the float bowl. The vent tube that goes down to the bottom of the bike is where the gas drains to. Put the jar under that tube and start to unscrew that screw, enough so that the gas leaks into that jar. Once the gas doesn’t drip anymore, close the screw all the way. Now on to the top of the carb. We are going to take this cover off:
      This cover comes off by removing the two screws. Once removed, the lid comes off as well as the gasket. Flip it over and set it aside. Do not set the gasket side down on the ground, as it will get contaminants! Here is what you are facing:
      The angle of the camera cannot show the two screws. But one is visible. It has a red dot, and opposite of that side is a darker red dot. I made it darker because it’s not visible, but that is where it is. This is where I use the miniature screw drivers to get the screws. I magnetize the screwdrivers, and use care to make sure I don’t strip the heads. Metal pieces in a piston are not good! Remove the two screws. Put these screws on a clean surface so they do not get contaminants. Now get your vise grips and set it so that it will lock onto the throttle, not too tight, not too loose. Set the vise grips on the seat. Start to open the throttle slowly as you guide that “plunger holder” (as I call it) up to the top. Once you have the throttle all the way open, take the vise grips, and lock it so that the throttle does not go back any more. What I do is I hold it pinned and lock it up against the brake so it doesn’t rewind on me. If you don’t have locking grips, a friend will do, just have them hold the throttle open all the way until you are finished. How fold the plunger holder to the back of the carb and pull the piece up to the top. Take care not to remove it, as it is a pain to get back together! If it came apart on you, this is what it should be assembled to:
      Once you get the holder out of the slider, set it back like this:
      As you can see, the bar is back 45 degrees, while the holder is forward 45 degrees to make a S. Here is what you are faced with when you look down on the carb:
      Where the red dot is where the needle lies. Grab needle nose pliers and carefully pull up the needle out of its slot. This is what the needle looks like once it is out.
      Now we must move the carb to take the bowl off. Untie the two straps on the front and back of the carb. Don’t take them off; just loosen them until the threads are at the end. Take the front of the carb off the boot and twist the bowl as much as you can towards you. Tie the back tie down to that it does not rewind back on you. This is what you have:
      Now we must take off the bowl. Some people take that hex nut off to change the main jet, which you can, but you cannot access the pilot jet, and you can’t take out the needle jet (a piece the needle slides into), so we need to take it off. It’s just three bolts. As we look at the underside of the carb, this is what you will see:
      The bolts with the red square dots are the bolts you will be removing. These are Phillips head bolts, and the bolt with the blue dot is your fuel screw. This is what you will adjust when the time comes, but keep in mind where that bolt is. You need a small flat blade to adjust it.
      Well, take those screws off, and you are faced with this:
      The blue dot is for cross reference, which is the fuel screw once again. The green dot is the pilot jet. You can remove this using a flat blade screwdriver. Just unscrew it and pull it out. Once you pull it out, set it aside and put in the 45 pilot jet you got. The red dot is the main. You remove this by using a 6mm socket. Just unscrew it. If the whole thing turns, not just the jet, but the 7mm sized socket under it, don’t worry, that piece has to come out as well. If it doesn’t, use a 7mm to unscrew it off. Here is what the jets look like:
      Pilot Jet
      Main jet attached to the tube. Take the main jet off by using an open end wrench and a socket on the jet. Again, it screws right off.
      Here is what you are faced with if you look form the bottom up.
      From left to right: Main jet, Pilot Jet, Fuel screw. Now in the main jet’s hole, if you look closely, you see a bronze piece in the middle of that hole. We are going to take this off. Since I did not do this part (I only changed my pilot jet when I took these pictures) there are no pictures taken for this section but this is really simple to do if you’ve been a good student and know where things go. You should know anyways, you have to put the bike back together!
      (Notice: There have been discussions about these needle jets being the same. Only change this needle jet if the one you have is worn out. If you do not have the old needle, a older drill bit bigger than 3/20ths (.150), and smaller than 11/100 (.11") Use the tapered side of the bit, set it down in the hole and tap it out carefully.)
      Now take your OLD needle, I repeat, the OLD needle because what you are going to do next will ruin it. Pull the clip off with your needle nose pliers, or a tiny screwdriver to pry it off. Then put the needle back in the hole where it goes. That’s right, just to clarify, you took off the needle, and you put the needle back in the hole with no clip. Slide the point side first, just as it would go normally. Now if you look at the bottom of the carb, the needle is protruding past the main jets hole. Grab another pair of locking pliers (vise grips as I call them) and lock it as tight as you can on the needle. Pull with all your might on the needle. Use two hands. Have a friend hold the carb so you don’t pull it off the boot. Tell them to stick their fingers in the hole that goes to the engine, and pull up. After pulling hard, the needle jet should slip right off. Then notice which side goes towards the top of the carb. There is one side that is a smaller diameter than the other. Take the new needle jet, and push it up into the hole the way the old one was set. Just get it straight. Take the tube the main jet goes into, and start threading it in. Once you can’t tie it down anymore with a ratchet, unscrew it and look at the needle jet to make sure it’s set. That’s it for the needle jet. Now let’s start putting the carb back together.
      (Notice: Many people have destroyed jets and such by overtighting them! Use the thumb on the head of the wrench and two fingers on the wrench to tighten it down.)
      Thread the main jet into the tube it goes into, and then start putting it back on the carb. Thread the pilot jet in as well if you haven’t done so already. Remember these carburetor metals are soft as cheese, so don’t over tighten the jets very much. What I do is I put my thumb on the top of my ratchet, and use two fingers closest to the head of the ratchet to tighten the jet. That’s how tight I go when I tie them back in.
      Now before we put the carb back together, let’s adjust the fuel screw. Take a small screwdriver, and start screwing in the fuel screw until it sets. Again, do not over tighten, just let it set. Then count back your turns. Count back 1.75 turns.
      Now we must put the bowl back on. The white piece that came off with the bowl goes back as followed:
      If you look directly under the carb, the round hole is aligned with the pilot jet. Take the float bowl, and put it back on.
      Untie the rear clamp and the front clamp as well. Slip the carb back the way it used to. Make sure that it is straight up and down with the rest of the bike. The notch on the front boot should be aligned with the notch on the carburetor, and the notch on the carburetor should be in that slot. Tie the clamps down securely.
      Let’s put the needle in. These are how the needle numbers go:
      The top clip position is #1, the lowest one, closest to the bottom, is #5. (The picture says six but it is five in this case) For reference #1 is the leanest position, while 5 is the richest. I put the clip in the 4th position. Read at the bottom of the page and you can know what conditions I ride in, and you can adjust them to your preference.
      Put the clip in the new needle, slip it in. Take the vise grips off your grips and start guiding the plunger holder down to the bottom. Remember not to let that assembly come apart because it is a pain in the ass to get it back together! Once you get it to the bottom, put the two screws on, and then put the cover on.
      Now that you have done the carburetor mods, there is still one thing you want to do to complete the process. Don’t worry, this takes less than a minute! On the top of the air box there is a snorkel:
      As you can see, you can slip your fingers in and pull it out. Do that. This lets more air in to the air box. Don’t worry about water getting in. There is a lip that is about 1/8” high that doesn’t let water in. When you wash, don’t spray a lot under the seat, but don’t worry about it too much.
      The next thing you must do is remove the exhaust baffle. The screw is a torx type, or you can carefully use an allen wrench and take care not to strip it:
      The screw is at the 5 o’clock position and all you do is unscrew it, reach in, and yank it out. This setup still passes the dB test. The bike runs 92 dB per AMA standards, which is acceptable. Just carry this baffle in your gear bag if the ranger is a jerk off. I’ve never had a problem, but don’t take chances.
      That’s it! Start putting your tank on, seat, and covers. After you put the seat on, pull up on the front, and the middle of the seat to make sure the hooks set in place.
      Turn on the bike, and take a can of WD-40. Spray the WD-40 around the boot where it meets the carburetor. If the RPM rises, you know you have a leak, and the leak must be stopped. You must do this to make sure there are no leaks!
      Here is my configuration:
      04’ 230F
      Uni Air filter
      132 Main Jet
      45 Pilot Jet
      Power up needle, 4th clip position
      Fuel screw 1.75 turns out
      Riding elevation: 2000ft - Sea level
      Temperature – Around 60-90 degrees
      Spark Plug Tips
      When you jet your carb, a spark plug is a best friend. Make sure your spark plug is gapped correctly, (.035) but that’s not all that matters. You want to make sure the electrode is over the center, and you want the electrode to be parallel, not like a wave of a sea. Put in the plug, and run the bike for 15 mins, ride it around too then turn it off. Then take off the spark plug after letting the bike cool. The ceramic insulator should be tan, like a paper bag. If it is black, it is running rich, if it is white, it is running lean. The fuel screw should be turned out if it is running lean, and turned in if it is running rich. Go ¼ turns at a time until your plug is a nice tan color.
      Making sure your bike is jetted correctly
      While you are running the bike for those 15 mins to check the plug color, you want to make sure it’s jetted correctly now. Here is what the jets/needle/screw control:
      0- 3/8 throttle – Pilot jet
      ¼ to ¾ throttle – Needle
      5/8 – full throttle – Main jet
      0-Full – Fuel screw
      Pin the gas, does it bog much? Just put around, is it responsive? When you’re coming down a hill, the rpm’s are high and you have no hand on the throttle, does it pop? If it pops, it is lean and the pilot jet should be bigger. If it’s responsive your needle is set perfectly. You shouldn’t have to go any leaner than the 3rd position, but I put mine in the 4th position to get the most response. Your bike shouldn’t bog much when you have it pinned. If it does it is too rich of a main jet.
      Determining the plug color, you will have to mess with the fuel screw.
      That’s it, have fun jetting, and any questions, post on the forum, but remember to do a search first.
      Also, if your bike requires different jets due to alititude, humidity, or temperature, please post the following so we can better assist you:
      Average temperature
      Altitude (If you do not know this, there is a link in the Jetting forum that you can look up your alititude)
      Average Humidity
      What jets you are currently running
      What the problem is (If there is one)
      Just do that and we'll help you out the best we can.
      EDIT: The girl using this login name is my girlfriend. You can reach me on my new login name at 250Thumpher
      Then again, you're more than welcome to say hi to her!
      -Phill Vieira
    • By jason230
      Well I figured this would be a cool thread to have seeing as how quite a few of us have gotten pretty far into upgrading our 150/230s. This will be helpfull for those looking into getting things for their bike so they can see what everything looks like.
      '05 CRF230:
      -Acerbis Rally brush guards
      -Factory FX #'s
      -Renthal 7/8ths MC bend w/ soft half waffle grips
      -BBR +1/2" shift lever
      -BBR revbox
      -White Bros. R-4 Full Exhaust
      -Twin-Air and White Bros. airfilters
      -White Bros. 112main and 48pilot jets
      -Dunlop D756's w/ MSR Ultra Heavy Duty tubes
