2001 wr290f jetting help
hi all just rebuilt my 2001 wr250f with a fmf powerbomb header powercore 4 silencer and a athena 290 kit the jetting is spot on above 1/4 throttle i just cant seem to get it right from idle to a 1/4 the exhaust is glowing within in seconds and it wont idle unless i turn the tickover right up high got the fuel screw at nearly 3 turns out and its getting better so im thinking a bigger pilot or leak jet? rang my local dealer today and he said leak jet not changeable on a 2001 anyone any ideas what else i can try? cant get a jd jet kit here in uk all jetting is on the idle circuit is stock apart from the fuel screw being nearly 3 turns out
cheers in advance ian
I agree, sounds like bad/dirty pilot jet.
I would question the tid bit about your leak jet, I could swear they are changeable.
check out www.thumperfaq.com discussion about the accelerator pump circuit and the role of the leak jet....
