2001 400ex Smoking Problem
Hey guys, I just picked up my 2001 400ex last week. And ever since, its been blowing some blue smoke. I think its burning oil. So i changed the oil and the oil filter, the oil was black. The original owner used 10W40 in it. I was told it may not smoke with 20W50 oil. So i tryed that instead. But its still blowing some smoke. Not as much as it was with the old 10W40 oil. Could it be the ring's? Or valves?
Thanks, Ryan.
20W50 and even 10W40 are way to thick for cold Nova Scotia weather! My mom use to live there, so I have heard the stories....
You might want to try an ester synthetic oil, like Maxima Extra. Synthetics have huge film strength, and will seal up loose tolerances better than any petroleum oil.
Most likely, it is your valve guides. They are always the first thing to go. But, it could be your rings, so you want to do a compression and leak down test to check that.
Valves are adjusted to spec???
What oil do you suggest? and nova scotia is like 10-30 Celesius in the sping, fall and summer ( not sure what that is in farenhite). 10W30. I'm not sure about the valves getting them adjusted soon.
Looking at my owner's manual, 10W30 is good from -15 to +30 degrees C. That is right in there for 3 season riding. If it is always on the colder end of the scale in winter (+5 or lower), I would run 5W30.
I run Redline for 10W30, and Maxima 530MX for a 5W30, but these are expensive high tech ester synthetics and you are unlikely to find them at a dealership.
For a less expensive petroleum oil, I like Maxima Premium. Strangely it doesn't come in 10W30 but does come in 5W30.
Thanks for the replys guys. And it also seems like it doesn't have as much power as it should... but i also drove a yz250f before i go it. Could there be something wrong with the bike power wise? or is it just me?
  • Similar Content
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By MrPickles
      I have a 1990 Suzuki RMX250 for sale.  It was bought from a friend who bent the crank back in 2000 and took it completely apart (down to the nuts, bolts, and washers).  The frame was powder coated black.  New crank case bearings, new gaskets for crank case, cylinder, and cylinder head.  All transmission bearings were cleaned and checked for wear or damage.  The crank was rebuilt and balanced by a local Harley shop.  New OEM piston and rings.  Cylinder and head are in excellent condition and worth almost as much as the entire bike, I think.  Brand new FMF Gold Fatty pipe.  New front and rear Renthal sprockets and new D.I.D. chain.  New grips.  Includes the original headlight and odometer (not shown), Mikuni TM38 carb has been cleaned and rebuilt.  Seat is original and in perfect condition. Runs perfectly.  Could use some new plastics, new foot pegs, front fork seals, rear tire, and a tune by someone better than I.  Pink slip in hand, but hasn't been registered in years.  Will throw in a Clymer manual.  The bike is a rocket and too tall for my 5'9" frame.  I'd like something a little more convenient to ride with my young kids. Asking $1800 OBO.  Serious inquiries only please.  Price doesn't include any shipping.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By Eachan
      I have recently been having problems with my honda mtx 125. It will run great for 10 minutes then it will die on me if i give it any throttle. The bike will idle fine but cuts out if I give it any gas. When I let it Idle for 1 minute it will work fine for another few minutes then the same problem happens.
      I have adjusted the carburetor many times to see if it was because its too lean or rich but the problem happens either way. I am running 40:1 fuel mixture. I recently replaced the head gasket and I noticed the piston needs replacing as its very worn, could this be the problem?
      Any advice/help would be greatly appreciated!
    • By Brady The Honda Guy
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
