xr70 idling/power issues
Well this is my first xr70 (had a xr50 before) and I just cant seem to get the thing to idle. It will idle better with the choke on but with it off I have to keep playing with the idle screw to keep it running. It seems to idle good for a minute and then wants to die. I already cleaned the carb out and it has stock jets. Is there any issues with these bikes like valves or anything of that sort, thanks.
There aren't any issues with the valves going out, but if they are set to tight, it wont want to idle right
Have you checked the clearance? I forget the exact specs by the book, but I run so .002 fits and .004 wont..
I think the valves are something like intake is .002-.004, and exhaust is .003-.005, but I'm not 100% sure.. My specs are fairly close, close enough that if they are set that way it'll run fine
Other then that, the pilot jet is soo small, you might need to run a piece of wire through it to make sure its clean, its a TINY pilot, and its built into the carb.
Thanks for the info. I'll take a look at it this weekend. BTW is it pretty easy to adjust the valves? I'm going to change the oil and take a look at the valves.
yeah they are REALLY simple, just pop the two caps off the head, spin the engine over tell it's at TDC (so the cams don't have a load on them) and check it.
The "proper" way to do it is to remove the cam cap also, the cam is on the left of the engine, the bolt to remove the round cap is on the right side its a 10mm..
But if you look at the cam lobes, you can just tell when the engine is close to TDC, when the lobes aren't pressing against the rockers.
IMO the carb pilot circuit is still stopped up. If it runs with choke on and not off it is to lean. If you never have checked the valves you should do that too but what you are saying points to the carb.
Well it does run with the choke off but once its warmed up it starts to almost lope and wants to die. Im going to change the gas and then check the valves and pilot hopefully this weekend, thanks for the tips.
I mean to say at idle. If you can get it reved up its not on the pilot circuit any longer. I have seen bikes where the owner keeps screwing the idle speed screw in so the thing is trying to idle with the slide held up. Real hard to control idle speed that way.
Take the pilot jet out heat with a propane torch to burn off any varnish, then stick one wire from a wire brush through it, should fit easily, If it does not it is clogged. Mixture screw should be 1 1/2 turns out and get a new plug. Get surgical with the carb make sure it is so clean the factory will have nothing on you or you can just get a new pilot jet. Mine did the same now runs like a champ after I cleaned the carb almost 3 times and heated the jets the last time, sprayed carb cleaner and dried w/compressed air.
Edited by BRPHondaRider
sausage fingers
Well this bike still isnt running good. I ended up just buying a new pilot and yet it still has idle issues. I'm wondering if its the floats? To me it almost seems to be running rich. I did also adjust the valves (a little loose) but it didnt seem to help. I did notice an exhuast leak from the head so I will have to fix that here soon. Anything else it might be? BTW I also drained the gas tank and put some fresh 91 gas in. This thing is becoming a real PITA.
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: http://tboltusa.com/store/lifan-125cc-enginebrsale-price-p-1811.html ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
