a little help setting my "S" for 60%trail / 40%street
Guys & Gals I need a little advise on how to set-up and equip my 2006 DRZ400S.
I am going to go thru the Faq section & do all recommended fixes/mods.
I am heading to Daytona tomorrow to pick it up. Looking at the pics, it has Pro taper Contour KX Hi bars which is good since I am 6'4, and a nice set of handguards....everything else looks oem. I ride mostly trail, but with the "Z" I think I will find myself on the highway more. I weigh #230(well... before Christmas anyway). Will I need any suspension mods(no i don't do triples, but will have it off the ground a bit)?
So this is what I am thinking so far:
-Pumper carb
-rear rack(leaning towards the Moose)
-Spitfire windscreen(no, I don't like the looks either, but I'll take it off for trail use)
-skid plate
-radiator shields
-Gps mount
-seatconcepts "Tall" seat cover for my arse
-case savers
-14T front sproket
-47T rear sprocket
Will I want/need these:
-different sprocket
-muffler(I like it fairly quiet...)
Ok...what am I missing...
Edited by Motor7
Add some case savers to the list.
I put a 14 t front sprocket on and run 44 t on the rear on the street and 47 t when off road at the moment. I don't run on the freeway with the 14/44 combination but it does ok on the local highways if you stay below 65-70 most of the time. I'm going to try 49 t to see if I like it better on the tight single track we have here in the NW.
The stock Trailwings have earned the nickname Deathwings off road for a good reason. At a minimum you will need DOT knobbies off road or non-DOT knobbies if you want the best traction. Two sets of wheels is kind of nice if you can swing it money wise.
At your weight you will need to respring and revalve the suspension, both ends. You can send them to Eddie at SSW or a trusted suspension shop if you know of one.
If you want quiet the stock pipe is the way to go. You can fit the E header on or the full E system if you want a little more flow. Unfortunately the pipes that make good power also make a fair bit more noise.
Something like a set of hotcams or E cams will be a good compliment to the Keihen carb.
Sounds like you're going to be having some fun in the near future.
Well, you are heavier than the suspension was designed for(me too!) after doing the RaceTech thing it was like night and day.
I started with a used 2002 DRZ400S. 1st Mod, FCR39, 2nd Mod, RaceTech for my weight.
Messed around with bunches of differant tires. I bought a second set of wheels,mounted Avon Distanzia's on them. Only good for hard pack trails(great street tire though)
Regarding tires, my favorite combo is almost any DOT knobby in the front and a Pirelli MT43 trials in the back. Very serious traction in most conditions except lots of mud. It handles the street more than OK, expect about 2500mi til burn out.
Gearing, Stock 15/46 is fine for light duty off road. 14/46 gives it a ton of nice low end. I swap back and forth a fair bit.
Muffler, stock works well, I like the advantage of stealth.
All this took my bike up to 16K, which included my son beating the snot out of the bike.
Latest mod, cylinder works 434 "big bore" and new head. Bike is now back to better than new(son is out of the club) 18 can buy his own now.....yeah sure!
Hope this helps.
Ok, I added the case savers & front sprocket. I'll keep the oem exhaust for now. I'll kick around a cam, but will it make much difference with a stocker exhaust? Tires/wheels, I already was thinking having one set for street, one for trail...but, man a set of extra wheels is kinda steep...I'll have to hunt around for a good deal
How much will the suspension up-grade cost...or should I go on Jenny Craig or...... not go home to Manitoba for Christmas where my MIL(who is a fantastic cook) will stuff me to the gills?
Eating with a smaller spoon saves $$ in so many ways.....
You would have to loose a lot to get down to 170 or so which is approx what the suspension is set for. New springs and valving for forks and shock will likely be around $400 or more. Send Eddie an email and ask him For price quotes and info pertaining to sales and service email SSpeedWorks@gmail.com,call 303-351-2390 . I've only done the forks as I don't weigh that much but it was the best mod I've done to improve the bike off road, well ok, non-DOT knobs were probably the best but until you get the bike tracking properly all the power in the world won't make you much faster.
170?... jeeze one would have to hit a crack pipe to drop that much weight...wait, that would be more expensive than a suspension mod:thinking:
Thanks for the ideas....the list continues to grow.
Edited by Motor7
Note on DOT knobbies, I run Kenda 760's and on the street with my son or GF they get down right scared in the corners. Hard to believe that aggressive knobies corner so well on the street.
I was all ready to go, even had the bike trailer hooked up to the TDI Jetta. My buddie called & said he was heading up to Daytona & would pick it up for me.... & store it in New Smyrna Beach....saved me that 20hrs of driving. Anyway, he rode it & gave it the thumbs up, I paid the balance & it's on his trailer.
Looks like I won't need tires right away, as it has Pirelli MT 21's on it & they are over 80%
He also said it has a new battery & was just serviced.
Now I may have to call some more favors in and get it leap frogged up closer to Tennessee.......:thumbsup:
I could probably be persuaded. It's a little longer drive from here but it's such crappy weather that it would take very little arm-twisting.
Actually, we are headed your way...Minnedosa MB for Christmas...driving 1600miles each way....need a delivery?
We stopped in Regina on our honeymoon('04) & I have to say we had a lot of fun cracking jokes about the way y'all pronounce it & what that rhymes with...:blah:. Hey...they wife is Canadian, so I can get away with it...:thumbsup:
You'll definitely have a white Christmas. We were on the edge of setting a new snowfall record for the month of November. Southern MB had at least as much as we did. You'all kept sending it up from the Dakotas and Montana. We always get a lot more snow out of those systems that pull the moisture up from the Gulf than we do from the ones coming over from the Left Coast.
I will be following this thread, cause I am in about the same boat..
Congrats on the new o6'. I just picked up mine a month or so ago. Lucky "you" got the purty blue and really low miles. :thumbsup:
I'm almost in TN, about 5-6 miles over the next ridge into Johnson county. TN's a big state, you could be 8 hours away.
Anyway, have fun tweaking the new bike this winter.
I'm near Morristown, just over Clinch Mtn. Boone has some good trails, eh?
I'm running MT21 front D606 rear, and it handles pretty awesome on the dirt, and not bad at all on the street.
I'm running 14/48 gear ration, and it was okay today on trails. I think I might prefer 13/48 if running some really slow tight technical stuff to avoid too much clutch work. I like 15/41 on the street, but 14/41 on street isn't bad. I have several sprockets and power impact tools, so switching is quick and easy.
I bought one of those closeout rear sprockets from Rocky Mtn, so a 14T front & a 47T rear is enroute.
you're 6'4", no one has mentioned it yet, but you should consider a set of bar risers: big dr bar risers are great but a little too short, or rox or others (check snowmobile foums and/or equip for ideas, go for something around 4" of rise pivoted forward for about 2" of reach: perfect for standing or sitting).
Definitely do springs and suspension fluid at least, valving even better.
mt21's are good for gentle dirt, 606 for better dirt, but go real knobby for serious stuff.
Power: cams won't make a huge diff, even with pipe and carb, but will help. With a big bore they reallly help.
Pipe: fmf bomb header with stock muffler drilled out end cap makes a good, quiet and effective pipe system (I have a full hindle and love it, but it's loud, even with a quiet core insert).
Rob, I haven't been able to coon finger the bike yet(still 600 miles away) & it looks to have adapters or risers on it. I agree, they don't look tall enough.
I already have a quote from Eddie on re-springing and re-valving the suspension. It's very reasonable, so when I get the bike here in Jan, it's all coming off & going to him.
The petcock is leaking...Pingle ordered.
I guess the dead of winter is a good time to do all of this, but dang.............an....tic............icipation:thumbsup:
I put Rox 3 1/2" on mine and I'm 6'. Great for stand up.
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
