95 KX500 Forks or 92 KX250 Forks?
I’m in the process of restoring my '92 KX250. The forks on the 250 are in good condition and operate well. But I have a front end of a '95 KX500 that I could use for this project. And they're a direct swap over, too. The lower tubes of the 500 are a larger diameter than the 250’s, and the 500's guards wrap around instead of the flat, narrow strip of plastic that the '92 250's have. I was wondering if anyone knows if the 95 500’s forks are an upgrade to the 92 250’s? Other than the exterior differences, are the internals improved/better enough to swap them over?
I think the 1995 KX500 forks are the same as the 1994 KX250/KX500 forks, so they are only two years older. I don't know that it would be much better.
Both inner, chrome tubes should be 43mm in diameter.
I have 1994-2003 fork guards on my '92 250. You will need the plastic holders that the guards slide through. They are a direct bolt on except the '92 doesn't use the side bolts like the newer forks. I had to trim the side edges down to work with my disc guard also.
KDXGarage: You’re right. The lower tubes are the same diameter. It was the axel on the ’95 500 that’s larger.
I was comparing the fork guards between the two and the newer wrap around type will work. Just need to trim the side tab off.
I think I’ll stick with the ‘92 forks on the 250.
Scottie_b205: Is the clutch pull on your 250 really hard? Other than the usual things like cable routing and lubrication, have you dealt with this?
Thank you for the information. I knew somewhere around those years was a bearing or something change.
Acually, it is kind of hard. I threw in a barnett clutch kit last winter and just figured the newer springs were stiffer then what came out. I have to inspect everything over again this winter since I could never get the cable pull correct. I had to over adjust everything out to get the correct play. Maybe the small ball in front of the actuator rod for the clutch fell out. I didn't really have any problems and I don't abuse the clutch.
What are you doing with the 500 forks? I'm looking for some (at least one) clean tube for my 94 restoration. The clutch cable wore a groove in mine and it's no good for re-annodizing.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
