2002 or 2006 CR250 HONDA
I am looking at two used two stroke CR250's. One is a 2002 ,and the other a 2006.
Both are in excellent condition with very low hours. Of course the 2006 is alot more money.
Considering both bikes in equal condition , would it be best to save some money and go for the '02 , since there is so little difference between years ?
Any opinions would be helpful.
Ya I would, they are practically the same bike with very few mods. I've got an 02 myself :thumbsup:
I owned an 03 and 06. They both handled about the same. The 03 had less of a mid range hit than the 06. Engine wise the 06 had a different cylinder, power-valve, and exhaust pipe. In my opinion the 03 was easier to ride. They both were fussy about jetting but the 06 was worse. Some people say these bikes were slow however I dis-agree. Since they are both Honda's the quality is very high. If I were you I'd buy the one with the least amount of wear and tear.
You're going to want to spend money on performance mods on both bikes. Save some dough, buy the 02 and let 'er rip!!
Typically I would say go newer. But I'm riding a perfect '03 and this thing rips. Also I can't leave anything stock personally so I would go with whatever bike is nicer and not really care what the year differences are because I tend to just end up throwing out 80% of the stock components in search of more power, better handling, anyhow.
So I say go with whichever one is least used. What sort of price difference are we talking here?
Equal condition? Go for the 02 and save some money. It would have to be a nice 02 though, and they are getting hard to find being that old. I think the difference for me would be the owners, and who seems to be in the know about routine maintenance. Check the model year changes sticky to see if you feel any of the changes warrant the 06's price difference. Also peek under the rad shrouds where they pass over the frame spars, they like to rub holes in the frame in that spot, moreso if the radiators are not perfectly straight. You have to slightly lift the shroud to see the area in question. Enjoy your new CR!
I say go with the 02. Like others said, save some money and use the difference somewhere else.
i agree go with the 02 i had a go off my mates great bike im looking for a 2001 model
I have an 02 and am very happy with it. However, the love really came after installing a Boyesen rad valve, Keihin 38 mm PWK Air Striker carb (I use a 2002 KTM 200 EXC carb that I got off of Ebay for about $65), and 49t rear sprocket. For enhanced reliability, install an MX Bonz airbox kit so that it does not suck dirt through the poorly designed stock set-up. You will never look back. It's as fast as a friend's stock CRF450 and has a very smoooooth powerband. I think people bad-mouth the bike because it's smooth like a 4-stroke. Just my 2 cents . . .
06 is a better starting point.
best advantage to the 02 is they are still green sticker in cali if I remember correct.
how big of a price difference? In California the 02 for sure for the green sticker reasons.. Everywhere else it depends on the price. I have heard the 02 had some handling quirks somthing like the rear end geometry wasnt quite right yet and they changed the linkage and valving on newer bikes. A good suspension tech should be able to fix the 02 handling issues though.
I'd buy the '02. If they haven't been maintained (seems most aren't) you're going to have to replace suspension bearings in either so use the money saved by buying the '02 and get it in tip top shape.
The 02-07 CR250's have the 3rd gen aluminum frame & are very similar bikes. They did make some changes every year & in 05 they went to a different engine & case design. You can look at the different model year changes on top of the sticky option in this forum for more info.. The 06 would be a better platform to start off with. I'd recomend riding both & going with the one you think is a better deal & option.
The main chassis difference is they pulled in the front axle blocks in 05 for better turning. I believe the swingarm has some different thicknesses for more or less flex? According to factory connection the linkage is better on the 03 which i believe is the same from 02-04. Like mentioned before the biggest changes were to the motor in 05-07. They tweaked the motor in 03,04.
02 you can bolt on a newer top end from an 06 that would matter if you really wanted to
Buy the 02 and use the money you saved on correcting the squish and a Rad Valve for starts. Swap the carb if you must.
how much of a price difference are we talking?? if its a couple hundred bucks id go with the 06, but if its more, id def go with the 02 and put some work into the bike, like everyone said they are very similar, cant go wrong with either one
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
