Fuel screw Q's
I just finished putting my 04 KX 250F's top end back together and I'm having a bear of a time starting it. I shimmed the valves and it has not helped it start any easier. I noticed that the fuel screw on the carb is 1 full turn out from bottoming out. Does that sound right? The last time I had it out, it flamed out and I couln't get it restarted. I checked the valves and they were all pretty tight. I checked my plug and it was wet. I changed it for a fresh one and it fouled as well. What am I doing wrong? I'm getting so frustrated :thumbsup:
well fuel screw should be ~2.25-2.5 turns out roughly can be less can be more but not much more.. limit is 2.75
How ever I am willing to bet you have your timing off or theres some sortof electrical problem.
Ok. I'll double check the timing marks and let you know what I find. Thanks!
i recently messed around with my fuel screw and it ran similar when i turned it that far in. it runs very well at around 2.5 - 2.75 turns out. hopefully thats all it is.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
