Sisneros Speed Works now offering complete ready to run motors!
Im making my personal DRZ motor collection and performance part collection available for purchase.
ive got any thing from stock E, S/M and kicker motors to full on built versions of the same. most have been run on the dyno only or have less than hour of run time on them.
email me with any interest. i can also build to order pretty much any combo you could ever want.
On complete motors, is a core exchange type of thing possible? For instance, if I buy a complete motor ready to bolt in would I be able to get a credit back if I send you my motor?
yes,no problem if the motor is runnning undamaged motor. if the motor has had any failure i will need to inspect it first before deciding on if its worth any trade.
Very cool, thanks.
I may be hitting you up in February. Either for a build on my motor or one of yours.
lets call it a "stack" of motors.
stock kicker is no problem. i also have a 3.5 mm (custom) stroke w/4mm bore kicker motor that you could do a choice of head set ups. stock head all the way to full SSW head.
basically i can mix and match parts to build almost any configuration. 4mm bore,stock stroke. 3.5mm stroke,stock bore. stock bore,stock stroke,etc etc.
for E/S/SM stock stroke and 4mm stroke available as well.
i also have a nice used MRD/SSW pipe.
nice used hotcams.
this is all stuff ive purchased for testing and development for SSW.
so for some reason i can't make e-mail work as it says i don't some type of account set up , can i pm you for a price on a E model of some build type ( stock or maybe?)thanks Ed
Bringing new meaning to " Plug and Play" !!
Excellent offer!
Too bad freight is so much!
Going to send you my head early in 2011 Eddie for some work if you like?
Sent you a Gmail
Sounds like a great idea. Will this make the bike a canditate for a salvage title, as here in OH, If you stuff a motor bought from a salvage yard and install it into your frame with the original engine/frame not matching you have to change the title to a salvage title. Im not sure of this. Please advise.
I dont think motorcycle frames and their original engines share the same vin numbers like cars do.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
