Will a YZ 125 and YZ 250 parts interchange?
I'm thinking about buying a 2004 YZ 125, to have a extra set of suspension for my 2004 YZ 250. I don't think they will have any problem but haven't been able to look close enough at both to make sure. I figure the only difference between them are probably the spring rates. Am I correct? If so will most other parts also interchange (wheels, brake calipers, ect...)?
Thanks in advance.
I believe most parts are inter-changeable.. Especially on like years..
Spring rates and valving are different, if talking about the same year parts.
even the wheels too? (hub, brake rotor, rim)
Spring rates and valving were different but everything should mount right up.
Yes, However, the rims themselves are different widths :smirk: But the hubs will mount up
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
