starter issue?
I've got a 94 650xl that sits a fair amount and the battery was always barely able to start it and then was dead. Charged the battery on a trickle charger for a day and all I get is a single click near the battery, solenoid? I bought a new battery because I needed one anyway but the same thing, just a click, no spin. Any ideas. Thanks
The starter relay. I think the stock location is in the battery box. You could also "jump" the starter with a heavy lead from the good battery to the postive pole on the starter to bypass the relay, to check that is your problem.
So I tried a novel approach and read my manual, the trouble shooting chart indicates that if there is "clickiing" then it is the starter not the relay. Indeed, I pulled the starter and it was frozen. I got it freed up and reinstalled it for the mean time and will source a new starter motor. Thanks.
you can get rebuild kits for them for around $30.
+1 on PDX's advice. It is unlikely that your starter is shot. Most likely a rebuild will get it back in the game.
Or you can get a used one with a rebuild kit thrown in for about 50 clams on AD the fleamarket for sale by kubiak...:smirk:
Thanks for the heads up, a rebuild kit I shall seek.
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
