New engine storage
Just got a new ccm e engine at good price in case mine implodes whats best way to store it ?? was just gonna leave in crate in house in a corner till needed will this be ok
without knowing how it was prepped before crating? Stored inside in a controlled temp low moisture area is a GREAT idea though. But I would check or prep it your self.
I would uncrate the motor, use some fogging oil in the cylinder, I'd spray some in every open case hole.. ... I would get some desiccant packs, bag the motor with desiccant inside.. And re crate.. Then mark your calendar in 3 months, uncrate and check the desiccant and visually the motor. If all is well, put her to sleep again until you need her.
Best way is to send it to me... I can store it here in dry Arizona storage and keep an eye on it for ya. :smirk:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
