Fuel pouring out!!!!
Well lately my 05 has been hard to start, and i checked the valves about a month ago and they are perfect and i have put maybe a hr or two on it since then. It has been jetted and un corked and runs amazing, but now all of a sudden its not wanting to start. I went out today to try and start it and when i turned on the fuel its just started pouring out of the overflow tube, even without touching the throtle, it just starts comeing out. Before i go tearing things down i just want to see what you guys think.
Sounds like the needles stuck: either the gas gummed up or you've got trash in it.
You can try tapping the carb body with a screwdriver handle and see if you can unstick it but most likely it'll be best if you just pull the carb and clean it out.
i tore it apart and cleaned everything and seemed to do the trick, some gas gumed up, i was thinking about a the 50 leak jet, but i already have a 48 and seems to be good, ill be bumping it up to a 50 soon though most likely
48 leak jet, or pilot jet??
I think you mean pilot, which is just fine.
The leak jet gives you proper throttle response. Stock is 70.
Whack it, smack it. But you're going to have to 'un-pack' it.
Carby clean time. New float needle.
Put in a 50 leak jet while your in there.
Kannie you said leak jet also haha, but yeah might be the pilot jet, went from i belive a 42, to a 48, helped a bunch
