Air Leak Issue
I am having an air leak issue that results in a lean surge when I let off the throttle from high speeds.:smirk: Early next week I will be addressing this issue by checking the rubber collar between the carb and rad valves and then if that doesn't have a leak, I will pull the stator and inspect the crank seal. These are the only 2 air leak trouble shoots that I am aware of.
Being that I am still a youngster, I would appreciate if any of you more experienced motorcycle enthusiats would make a troubleshoot list of air leaks for me.
Thank you for your time,
Ryan
the base gasket is another one
