Think I have a carb problem??????
I have a 2003 525exc that has not been used much in the last 4 years. Last time I rode it it was running like shit. I knew the valves were in bad shape so I rebuilt the the top end. I also cleaned the carb and jets but I might have missed cleaning some thing in their. The bike starts and idels but when you try to give it a little gas and take off it dies. When you are going down the road it runs good. It just tries to die when you take off. I am going to try taking the carb compleatly apart and clean it again.
Any other advice???
Thanks
Check your a/c pump. Could just be a stuck a/c rod or bad a/c diaphram. If its the diaphram, good time to upgrade to the honda diaphram (reduces the a/c squirt time to approx 1 sec.).
That statement, and loss of bottom end performance are screaming for a pilot jet replacement.
I have found that spraying the brass does not always work (especially the pilot jet). I take out all the brass bits and soak them overnight in carb cleaner. The "clean" looking jets will usually turn the clear cleaner yellow. Lots of gunk left.
Cheers,
MrHix
As already mentioned, check the AP fuel squirt. What you want to see is a nice, strong but short, roughly one second squirt.
