2011 Kawasaki Team Green suspension specs
FRONT FORKS REAR SHOCK
Rider Weight "Fork
Position
(height)*" Spring Rate "Oil
Level
Volume" "Oil
Weight" "Reb
Out" Comp Out Spring Rate "
SAG Level" Reb Out "Clicks
Comp Out Low " Turns Out Comp High Speed "Nitro
Pressure"
KX65ABF Pull Rods
55-65 15mm 2.55 N/mm Light 130mm 10 2**** n/a 46.1 N/mm Light 70mm 2**** **STK 140psi
65-75 10mm 2.65 N/mm Stock 130mm 10 2**** n/a 48.1 N/mm Stock 70mm 1.5**** **STK 140psi
75-85 Flush 2.75 N/mm Heavy 125mm 10 3**** n/a 48.1 N/mm Stock 70mm 1**** 85.3mm 140psi
KX85ABF
Up to 75 Std 2.65 N/mm Xtra Light 90mm 5 n/a 8 43.1 N/mm Xtra Light 80-85mm 9 1 150psi
75-100 Std 2.75 N/mm Light 90mm 5 n/a 8 45.0 N/mm Light 80-85mm 9 1 150psi
100-115 Std 2.84 N/mm Stock 90mm 5 n/a 8 47.0 N/mm Stock 80-85mm 8 1 150psi
115-125 Std 2.94 N/mm Heavy 80mm 5 n/a 8 49.0 N/mm Heavy 80-85mm 8 2 150psi
KX100DBF
70-85 Std 2.65 N/mm Xtra Light 90mm 5 n/a 8 43.1 N/mm Xtra Light 80-85mm 9 2 150psi
85-100 Std 2.75 N/mm Light 90mm 5 n/a 8 43.1 N/mm Light 80-85mm 9 2 150psi
100-115 Std 2.84 N/mm Stock 90mm 5 n/a 8 43.1 N/mm Stock 80-85mm 8 2 150psi
115-125 Std 2.94 N/mm Heavy 80mm 5 n/a 8 43.1 N/mm Heavy 80-85mm 8 2-3 150psi
KX250YBF
135-150 7mm 8.7 N/mm Light L-357cc R155cc 5 16 6-10 47 N/mm Xtra Light 100-104mm 11 8-12 2-3 150psi
150-160 7mm 8.7 N/mm Light L-377cc R175cc 5 16 6-10 49 N/mm Light 100-104mm 10 8-12 2-3 150psi
160-170 7mm 9.1 N/mm Stock L-377cc R175cc 5 14 6-10 51 N/mm stock 100-104mm 9 8-12 2-3 150psi
170-185 7mm 9.5 N/mm Heavy L-357cc R175cc 5 12 6-10 53 N/mm Heavy 100-104mm 8 8-12 2-3 150psi
KX450EBF
155-175 5mm 4.7 N/mm Stock +10cc 5 14 8-12 52 N/mm Light 100-104mm 12 10-14 1 - 2.0 150psi
175-185 5mm 4.8 N/mm Heavy 335cc 5 12 10-14 54 N/mm Stock 100-104mm 11 10-14 1 - 2.0 150psi
185-195 5mm 4.8 N/mm Heavy +10cc 5 12 8-12 56 N/mm Heavy 100-104mm 10 10-14 1 - 2.0 150psi
* Fork Height is measured from top of fork tube to top of fork clamp.
** 250/450 Recommended to have the axle pushed back, creating a longer wheelbase for improved stability and traction. This will require a longer chain. Taller riders may not benefit from the longer wheelbase.
**** Stock 86.3mm pull rods on the 2002-2009 KX65 can be exchanged for optional 85.3mm or 87.3mm to raise or lower the seat height by 4.5mm each.
***** Refer to the 2007-2011 KX65 owners's manual for position information.
FOOTNOTES - Rebound and compression adjustments are the number of clicks out from full hard (all the way in). Front fork oil level in millimeters (mm) is a measured distance or in cc's for a measured volume. Rear shock sag level is measured
in millimeters (mm). All optional spring part numbers can be found at your local Kawasaki dealership.
SPECIAL NOTE - Team Green recommends that any suspension sag measurements be done when shock is cold. Always test new setting before racing.
N/mm = Newtons / millimeter - Kgf = kilograms force
Conversion Formula for each method of measurement: N/mm Spring Rate x 0.102 = Kgf/mm Spring Rate and Kgf/mm Spring Rate x 9.807 = N/mm Spring Rate
*Team Green Specifications subject to change.
