A little info on gearing?
09 S model
I think stock gearing is 15/44 and the chain length is 110 links. Is this correct?
I just bought a 13T for the front and am waiting delivery. I want lower gearing for trails. Off the top of my head, my rear axle is set at about 4-5, and the chain is nice for tightness.
I should be fine with the stock chain and stuff right?
Stock S gearing is 15/44 and 112 links.
SM is 15/41 and 110 links.
Edit: With a 13 tooth, the axle will need to move back about 1/3 an inch.
Thanks for the reply. What is a 1/3" about a cm right? Can't wait to stop slipping the clutch in 1st.
Yes, about 1cm. 2.54cm per inch.
I think in metric and then always have to convert to inches.
You will most likely, unless your chain is stretched, get away with the stock chain.
Time to start a revolution man. You're the only country in the world sticking with that antiquated system.
you might find the 13 tooth a bit too low. I use a 14 tooth counter sprocket and a 47 on the back. It seems to work good for me. Plus, I could move my adjusters back to the front again and lots of room for stretch later if needed, all with stock chain.
Rumor around town is that 13/44 is the same as 14/47 I think the 13 on an S Is the simples cheapest way to get the bike to the same gearing as an E.?
yes.those ratios are virtually the same.the 13cs however will be harder on the chain life.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
