loosing coolant rad overflow pipe
as title keep loosing coolant any ideas wot to check
It does not normally loose water, so switching caps is not necessary, unless there is something abnormal going on.
My guess is that the gasket on the cap is dirty. Clean it with a brush under running water.
Also make sure the filler neck is perfectly round, it can become oval in crashes.
If this does not help, try a buddys cap. They fit from all bikes.
If that helps, buy a new cap!
cheers 1st thing i did was buy a new rad cap still loosing coolant though more dripping out than steam from overheating do a 20 min session and its lost a pint of coolant engine doesnt feel overly hot but will say the engine bangs and pops alot off the throttle
How much coolant are we talking about?
Are the radiator flutes clean...can you see through the rads? Water pump maybe failing causing overheating. A leaking head gasket can cause combustion pressure forcing coolant out. Is th coolant discolored at all?
BTW these bikes were not made to sit idle for very long so keep the air circulating through the radiators or it will boil over pretty quickly.
its not long had a full engine rebuild so from wot u mentioned i wouldnt be surprised ifa head gasket is leaking now is that from incorrect torque setting or does it need stripping down and replacing
If the head gasket leaks that way, you should be able to see some bubbles and/or some oil discoloration in the coolant.
I have the 2010 model and every time i ride coolant also comes out!!!!! i dont know why
coolant is not discoloured but might have bubbles getting it stripped down and checked anyway
iv started to get a few drips of coolent out of the overflow,the past few outings,
i dont no why it has started to do it now and not before, i think im just riding the bike harder, lol
i didnt take much notice of it??
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
