Kick stand & frame guards
Is there anyone out there who has successfully mounted a pro moto billet kickstand and a set of frame guards on a 2003 yz 250 (carbon fiber preferably)..There has to be something
mine is not a promoto but ...............
nor carbon fiber, mine are medal, what i did was just ground a notch in them and installed it.
Saw a thread somewhere in which there was a conflict between the mounting locations of the kick stand and the frame guard.
Guy trimmed the mounting points out of the frame guard to clear the kick stand, then drilled some holes and used zip-ties to hold the guard to the frame. Seemed to work well enough for him, and I notice that's how KTM retains their frame guards.
As mentioned in another thread, mount with clear silicone. That person mentioned he removes them using dental floss in a sawing motion. Sounds good to me!
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
