XR Six Fiddy R - Quick Suspension Question
Hey guys its been a while since i started a post so i might as well, just a quick question about whether having my suspension done would offer a large enough improvement to justify the $$$.
Recently i have been riding some rougher and knarlier types of hills and was wondering if having the suspension resprung or modified in any way would offer any improvement?
I weigh roughly 75-80kgs which i believe is close to what the bikes are made for and have the suspension settings at the recommended manual settings, would i get any improvement spending $$$ on the BRP's suspension?
If so whats involved, the cost and what parts etc or changed to help?
Thanks
Matt :smirk:
Tires, suspension and experience are the most important aspects in this sport. The question is if you feel the same way.
When you send in your stuff you'll be paying for a rebuild, revalve and possibly a respring. For the rebuild, they will replace the wear parts like oil, bushings and seals. For the revalve they will change out the shims on the valves to better suit your type of riding. Finally, if your weight is outside the stock spring range they will supply you with correct springs. In USD, it generally costs about $400-700 to have all this done.
You also want to call a few different tuners and talk to them and get a feel. Possibly look around online for opinions or reviews from people in your area who've used them. The xr650r suspension is pretty ehh out of the box compared to newer bikes. So most educated changes will be positive but no one is perfect so changes this person makes may not be something you like. This means you need to work with someone who will work with you.
If you're a DIY person then there is this page:
http://www.borynack.com/XR650R/
The 650R has fairly decent suspension as is. At 170ish lbs the springs don't need replacing, which is the BIG difference for most folks if they are signifcantly heavier.
Have you played with adjustability of the bike? Preload, compression, big differences there to be had.
But it's still a big heavy bike that wore me out on single track.
It is a big and heavy bike but for my purposes its the only bike that really does what i want. I may have a bit of a play with the settings on the bike and see any differences before i throw the $$$ at it.
Thanks for the info guys :smirk:
Thanks
Matt :smirk:
It's somewhat simple. Bruces' site helps a lot.
I ended up with about 6 more low speed compression shims (also, thicker than stock shims)on the rear,and just one more compression shim on the front.:rant:
Plus the heavier springs..
We've got BIG desert bumps out here!
My son and I have had 4 XR600Rs. Suspension revalving/respringing was the best money spent. We both weigh same as you. For the record, my '98 HRC628 with WP 4054 forks ad WP shock was no better in the suspension department than the stock forks and shock revalved by Factory Connection. WER is also one of the best for XR suspension. In your neck of the woods, you might want to talk to Ballards.
So you reckon its definitely worth checking it out? Is it just better parts that are available now that improve the suspension or just different settings and tweaks etc?
Thanks
Matt.
Slow down here.
A 650R has HELLUVA lot better suspension than a 600 did.
NOT the same thing!
XR600 can't be made to work "well" with stock suspension bits.
XR650R CAN, as long as the springs fit your weight.
AND THEY DO.
Slow down here.
NOT the same thing!
AND THEY DO.
So if the springs already suit my weight is there any improvements to be had?
Thats where im confused, as to how it can be improved.
It really comes down to how you ride it.... Do you hit bumps in 5 th gear that look like burried VWs'? Or do the bumps look like ground hog mounds.?
Sure it can be improved. NO doubt about that.
The question is whether YOU ride hard enough and/or rough enough terrain to need more than the decent stock suspension.
If money isn't an issue, then do it.
But can a 650r rider be perfectly happy with stock suspension?
Lots are.
LOL, that's an interesting way of setting a visual for those of us that don't see such things. :smirk:
Hmm the main reason i brought up this topic was because of the slower rougher terrain i have been doing recently, so does the majority of the improvement help the faster big hits? Along with jumps etc?
Thanks
Matt.
  • Similar Content
    • By photonicreno
      Hi all!
       I've got an issue, one of many when it comes to bikes. I searched throughout all the pages I could find pertaining to my situation and couldn't find very much useful information.
      So the issue is, the bike has no electric start.... until it's hot enough to melt steel that is. It will bump start first time every time. But I can sit and crank the starter over for ever and it'll never start until the charger is bumped up past 200 amps. Not good.
       The story so far,
      Got the bike for 1k cash. Guy said it has no spark and no second gear. This particular guy also only ever rode newer crotch rockets. Brought it home pulled the choke, attached battery charger and she fired right up. Ran like absolute crap, but oh well I figure it's an older bike with only 10k miles so it probably needs a good carb cleaning. Took the carb apart and didn't know I messed something up until way later(didn't tighten down main jet). Oh well she runs well enough if I can get her started. Moved from California to Oklahoma. Eventually found the money to fix 2nd gear, and as I am a certified Honda small engine technician apprentice I figured it would be no big deal. Completely tore down engine to it's roots replaced 2nd, and 5th gear(because 5th gear connects to 2nd on the countershaft) dogs were worn pretty badly on both. The engine looked quite good compared to most others I've seen. Put the engine back together as per the service manual. Did all the right steps including loosening the banjo bolts to test for proper oil pressure. I even tore apart the electric starter to clean the contacts and the brushes and replace the dielectric grease. Adjusted the valves as per the service manual, replaced all gaskets, o-rings, seals, and oil filter.
       Finally after about a month of waiting on parts and reassembly I get to start her, only she doesn't. Electric start is still giving me the same issues I've always had. So I replaced the Ignition coil, CDI box, and put a new battery in, plus the starter motor rebuild. Nothing. Still cranks forever. I said what the heck and tried to push it slightly down hill and bump start it, and voila... fired right up! Once she gets hot enough and the stator charges the battery enough it'll electric start... sometimes.
       So I looked towards ignition, used a tool called ignition mate. Pretty awesome tool if you can afford it. Well while cranking the ignition mate reads the spark plug is getting 1-4kw of "spark" every cycle, well it only fires after getting up past 5kw sometimes 6-8kw. And sometimes the ignition would be intermittent as in it wouldn't give any spark at all. I cycle the ignition and it seems to soft reset the bike as it will usually give it back spark. I tested this with the new and old CDI box, the old one would never spark. Ever. So I threw it in the trash. A month later I stil l can't figure it out.
       Is there something I'm missing?
      TL;DR
      Bike won't start using electric start only bump start before and after engine rebuild
      Electric start works after pushing the starter past about 200 cold cranking amps or when hot.
    • By TheLastByte
      Contemplating picking up a BRP in the near future and looking for some perspective.The current owner claims that the bike has about six hundred hours on it, but there's no way for me to confirm as the odo's not accurate.
      I know brp's have a reputation for running forever on stock top ends, but they must eventually have an expiration date. What should I look for on a high mileage bike like this to make sure I'm not setting myself up for disappointment? Also, What are some non engine/transmission related issues I should look for?
    • By TanSnowman51
      Guys,
      Have been riding my 650L for over a year and a half and have been loving every second! In August I moved back to Reno after finishing up my masters at Arizona State. I have been spending most of my time riding around verdi to stampede and the Dog Valley road area. Always looking for riding buddies.
      Was curious what everyone was doing as far as Daves mods or jet kit for the upper elevations 4,000 to 8,000 feet?
      FMF Q4 exhaust, smog delete done so far!
      Thanks!
    • By Alexandre Askmo
      Hey dear folk!
      I need your help.
      A bit of background info, I’m a complete noob when it comes to holding a wrench and doing anything more than filling up the bike. I have however had an interest for as long as I’ve had a bike to make it mine, and that’s why I’m writing to you now. I just bought a donor bike, a Honda NX650 which a friend of mine is helping me fix up and then modify to my liking (I’m hoping to end up with a gorgeous scrambler in about 9 months).
      We found a hairline scratch in the cylinder and need to bore it. This leads me to my question.
      Should I get a 1st overbore performance piston or keep the compression ratio as is? If so is there anything in particular I will need to modify to tolerate the high compression piston?
      If I do get the performance piston, should I also get a new carburetor, hot cam, and new exhausts? I am planning on new exhausts anyway (2-1 from an XRL) and I’m planning on removing the airbox and getting a K/N pod air filter.
      Again, keep in mind I know nothing, my friend has however fixed up a bunch of XRLs and cars but never really used performance parts. Help me out with the decision please, I would also like to keep the whole build to a reasonable cost (I know this is a very relative number).
      I should also add that I want to keep the DNA of the bike, for example keeping the fuel tank instead of switching to a smaller rounder one as one usually sees in most custom builds. The aim of the whole build is to have an insanely fun bike to ride, both in the city and off-road, as well as giving it a bunch of my personality 😊
      Thanks a lot for any help!
      Best,
      Alex
    • By MrCitizen
      I've been rebuilding/restoring an XR650R for some years now (after toasting the motor in 2013). Sent the motor off to be rebuilt, had a local shop rebuild my forks and shock, and took care of most everything else myself.
      As of a couple months ago I had almost everything assembled and ready to run.
      As a final check before adding fluids to the bike, I decided to stick my boroscope into cylinder and take a look. The results were concerning.
      These boroscope pics looked so gnarly that I pulled the head off the motor to get a more thorough look.
      To say that I'm concerned is an understatement. I have pics of the motor internals pre-rebuild, and can confirm that this is definitely a new piston and replated cylinder. I also have all the old parts from the motor, so it does have a new cam, connecting rod, valves, and basically everything else I expected to have replaced.
      The builder "ran the motor briefly to confirm everything ran alright" and then shipped it back to me. I reached out to him with these pics and he said,
      The piston looks like this because he had it machined from 12:1 to 11:1 compression. The streaks on the cylinder wall are normal for one that isn't broken in yet. Regarding the valve impacts in the piston head: "My concern is that something may have passed through the cylinder. How does it run?" I've never run this motor. I can feel these streaks in the cylinder wall with my fingernail. Did he re-use a piston from some other motor?
      Is this dude jerking my chain or is this motor fine to run?
      He's a fairly well-known builder in the XR community and was recommended to me by guys in the (now-gone) XR650R forum.
