Stock shim stack KTM 525 SX 2006
Can anyone tell me the stock shim setting (fork and shock) of my KTM 525 SX 2006? I´m not sure if the previous owner has changed the shims and I want the suspension setup to be stadard.
Many thanks in advance!
Stock 2007 450/505 SXF Stack 1.2bar bladder .46 springs
7-24x0.15
1-17x0.1
1-22x0.15
1-20x0.15
1-18x0.15
1-16x0.15
1-14x0.15
1-12x0.15
1-10x0.2
2007 450/505 SXS Stack 2bar bladder .42 springs
6-24x0.1
1-18x0.1
8-24x0.1
2-23x0.1
2-22x0.1
2-21x0.1
2-20x0.1
1-19x0.1
1-18x0.1
1-17x0.1
1-16x0.1
1-15x0.1
1-14x0.1
2-13x0.1
Mid valve for both with 0.3mm float
5-20x0.1
3-18x0.1
2-16x0.1
1-11x0.2
Rebound stack for SXF
3-20x0.1
1-13x0.1
1-16x0.1
1-14x0.1
1-13x0.1
1-12x0.1
1-11x0.3
1-16x0.25
Rebound stack for SXS
3-20x0.1
1-13x0.1
1-16x0.1
1-14x0.1
1-13x0.1
1-12x0.1
1-11x0.3
1-14x0.25
Piston part numbers are the same. The main difference I noted in the manual is the SXS has internally adjustable preload
I like the sxs settings better than sx personally.Never get the suspension to work well with 0.15mm shims, But use 1.2 bar and std springs for a 180lb rider.
-06 model has OC fork if I remember correct. Sorry I don't have listed -06 settings. Have you checked www.valvinglogic.com yet?
:smirk:
it's an OC fork with an external preload adjuster
bugger LOL forgot that small fact.
Thank you for your answers.
Yes its an OC fork. Yes I checked www.valvinglogic.com but I could not find any useful information for the 06 model.
however that sxs fork setting actually works well(much better than std) in the oc fork with a tad more lift,
Mid valve with 0.6mm float
5-20x0.1
1-18x0.1
1-16x0.1
1-11x0.2
