Sprocket keeps coming loose
My sprocket on my 2010 keeps coming loose. I have to tighten it after every ride. And by loose I mean about to fall off.
I never have this problem but I would try small lock washers and some blue lok tite. Let the lok tite set up for a couple of hours before riding.
Front sprocket or rear sprocket?
Was this from day one with the original sprocket, or after a change was made?
Its the rear and yes I put a 50t Pro taper on it.
If it has come loose several times your hub is probably shot. Once the holes get elongated it's a disaster waiting to happen. Check the hub very closely. If the holes are elongated at all, replace it asap. Don't ride it! I always use blue loctite on sprocket bolts and have never had one come loose.
