Tire Size Questions, Front & Rear
I am looking for some wisdom on tire sizes. Firstly on the rear, the previous owner of my bike had a 110/90-19 on the rear. Searching the forum, I have read that the rim is not made for that tire but if you want the wider tire get a 110/80-19. Using this size greatly reduces the amount of brands available. Secondly, the previous owner had a 90/80-21 on the front which is a little wider than stock. What are the advantages/disadvantages of the wider tire on the front .vs. the 80/80-21. Thanks
Tire sizes are only comparable within the same brand of tire. And often only within the same tire designation.
Your bike came with a 1.85" rear rim and a 100 width tire. That rim can accept most 110 tires no problem. It will be slightly wider (10mm in theory) and heavier. Usually a wider tire means more traction, sometimes too much for this smaller engine.
A 110 Michelin will not have exactly the same width as a 110 Maxxis and so on.
Some people like it, and some do not. It will depend on the track, tire itself and the rider´s liking.
The smaller rim will (with some tires) make the tire profile rounder, although not by much.
I personally often run the wider tire.
As for the front, a wider tire will leave a wider footprint, but can feel bouncier if it has a larger volume than the other tire.
90/90 is translated as width 90mm, and the second number is the tire side height in % of the width.
A 80/90 tire will be narrower, and have sidewall height 90% of 80mm. So this tire will hold less air and give different feeling. It will also put more pressure on a smaller surface.
All of this, including tire pressure variations, requires too much testing for a casual rider really.
Bottom line is, test for yourself! No tire will be downright wrong, as long as it fits the rim. You are the one who has to feel comfortable riding with it.
I prefer to buy tires from the same place, this way I know they will have the same tires every time. And when feeling brave I try out a new tire:thumbsup:
Thanks D-K, good info.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
