XR lights on 230 as running lights?
Wire into the ignition switch so you don't inadvertently run down the battery, which is why I like AC lights; when the engine stops the lights go out.
AC lights with small altinator sucks. You hit brake and headlignt dims.
I never turn key off, it is under my odometer.
Lights are wired to a left hand switch which has "Off" (nothing works), "Tail" (tail, brake, & turn works), & "Head" (everything works).
