Where is THE XR250L info?
Here's one I wrote, but there is lots of other info also available; use the search function on ThumperTalk or try Google:
XR250L Project :smirk::rant:
Thank you!
I printed it off to read thru it later. Looks like alot of good info in there.
Can you say if there is 1 mod that was the most bang for the buck?
I just bought the bike and maybe it has old gas in it but it's doesn't like to kickstart right away (kind of chilly out). Has a pretty big bog off idle too. And the throttle has a slight stick or catch off idle.
Any advice? Thanks!
(anyone know where I can buy new blue fork boots for it that fit near perfect?)
Not sure about the best mod but maybe jetting, exhaust and header grinding should see a significant improvement. Just the headers was noticeable for me.
As for bog there is a thread around here that discusses cutting the spring next to the carb by like 20% for a quicker throttle response.
There is a ton of info on this subject here shouldn't be hard to find good luck.
