Arenacross testing/tuning?
I have a 2006 YZ250, with stock suspension, which works pretty well for me actually. I'm around 180 in gear, and 6'2" and stock springs are close to perfect from just looking at the calculators on line.
I have my settings alright from racing outdoors, and am comfortable recognizing some of the feelings on a rough track and correcting them. My question is what do you feel for, and how do you correct it on an arenacross/supercross style track?
There's a race coming up in a couple weeks, where I'll have a fair amount of time in the practice sessions, so I should have time to make some changes if theres something wrong. I just want to know what you change heading to a smooth track with huge whoops and steep faces, coming from worn out out doors tracks?
I'm thinking less sag, drop the clamps a little, and speed up the rebound/stiffen the compression. Is that headed in the right general direction?
Also, what do you feel for on a track like that? I expect the whoops to be a bit of a rodeo, being much steeper and closer than out doors. What settings keep the nose up? how far do you want to go with keeping the forks high? what keeps the rear tracking straight? what keeps it from kicking up?
I'd be ok trading a little bit on turn in for some extra stability, as far as compromising goes, but I don't know when to change static settings like fork height and sag, and when to change the damping settings; I've never tuned for the slower speeds, and artificial obstacles before.
Anyway sorry for the long post, thanks in advance for any help you can give me
to setup for real SX you would change the base valve stack shims from the stock .11 thickness to .25 x 5 on the face shims and .2 thickness on the rest while increasing the clamping shim 4mm in dia. That is just a place to start. It sounds stiff but that is what the Pros use only they go even stiffer.
Note im no expert in suspension
But i have been using my normal suspension setup on arenacross like track with woops etc.
You want the forks stiff: 0-5 clicks out on comp ,rebound i run the same as on normal hardpack , raise oil hight
Shock: sag 100mm, comp 1/2 turn +5 clicks out rebound 4-5 clicks out
this is what i have found works for me (without using money), its quite far from what i run outdoor but it might give you an idea
Kim
I realize I won't be on real supercross suspension with stock valving, but I only ride arenacross 1 or 2 nights a year, so I was hoping to just ride it without having to do more than oil height and clicker adjustments.
Kim
Ok cool, thanks! out of curiosity what are you at generally for normal hardpack? my forks are usually around 8-10Comp, 10-11Reb and my shock is 1 1/4 HS, 9-11 Comp, 11-12 Reb. Just for reference so I can change about of the same amount.
Thanks again, and what do you adjust for after your first couple laps testing wise?
We cant compare our suspension to the last click
but some where around the same ,i do run reb on forks around 14-15 though
(hard pack stock susp with mods,)
just try the woops with your normal settings ,then try what i suggested and go from there
you want stiff forks when coming up short
and your shock stiff and with a lot of rebound in the woops
Good luck im sure you will have fun:thumbsup:
Kim
450DK, Thanks again for the help. I ran my normal settings in practice, and the first night, and the second day I tried your advice. It made a huge difference keeping the front up in the whoops, and as an added bonus, seemed to help in the G-outs between transitions in the very tightest rhythm section.
:thumbsup:
And you didnt hurt yourself??
Not a scratch :thumbsup: Actually 3 of us went and only one guy had a real spill, but we all walked away healthy. I dunno if I'd ride it every week, but for a once a year thing, it's fun :bonk:
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
