ISDE vs Champions Edition
not much that i know of, my buddy has the 450 champ edition and i have the 530 6day edition, i think his came with orange anodized front brake res. cover and hydro clutch handle cover and 4 less horsepower.....oh and red bull graphics....but not much else that i can think of there basically the same bike same weight, just a 4 hp difference
Thanks, all I could see was the difference in graphics. If you think of anything else let me know. Looks like I'm getting a used Champions 450 but i see way more 2010 ISDE left overs by dealers than Champions...actually I don't see any left over Champions.
Make sure you check the difference with someone knowledgeable - from what I understand these bikes use different frames, motor sits different in Six days and these are two completely different set ups. That is what I was told when I was looking to purchase - I have a 11 530 Six days....
Good luck on your search!
Speaking for what I've heard/read not experienced first hand.
2010 Champion is supposed to be 2009 Factory Left over with some added factory *bling* I just bought a 450XCW Champ about 2 weeks ago.
Six Days has some updated parts for '10 (aka frame, piston rings) a coolant fan, and different graphics. There are more updated parts, but I don't know them all.
I was told by the Factory Rep. that the Champions Edition had the 2010 engine improvements but he was unsure about the frame and air box design. This makes sense since the web site listed these changes for the rest of the 2010 EXC series. One thing I noticed though, is that the KTM radiator braces will not work with the 2010 EXC CE (nor will the 2009 & prior air filters fit). I tried to install the braces and they will not fit and this leads me to think that some changes may have been made to this frame compared to earlier models.
I know these issues are supposedly settled but I wanted to report on what I've experienced with my bike.
Hey Super Dave - thanks for the link but the specs referred to in the KTM Talk post from FunMart Cycle are no longer available. I'm certainly not out to make the Champions Edition something it's not but as per my post there seem to be differences in parts between 2009 and these models. My experience is that it is not just a gussied up 2009 and I also base that on what I reported from the KTM factory rep. Even if I'm wrong the EXC is a great dual sport and I love riding it. Although the break in issues have been a hassle as I have reported in various posts the issues I've had with fuel tanks/carb, overheating, gearing, etc..
We are planning on visiting your fine state this summer and do some riding at Moab - friends report that it is a fantastic experience. All the best.
I used to live in Iowa, Spirit Lake so I can say this in jest:thumbsup:
IAoffroader, that's a oxymoron :smirk:
sorry couldn't help myself:ride:
2010 CE has the 2009 frame and suspension, the rest I dont know for sure, but I had all 3 parked parked side by side when I bought mine and the frames are different for sure
my google search turned up this
2010 KTM 530 EXC Champions Edition (Street Legal)
» The year 2009 is the 35th anniversary of KTM´s first World Championship title won by G. Moiseev back in 1974.
Limited Edition Kini Red Bull Graphics
$400 KTM PowerWear Certificate
Headlight and Tail Light
Quick Release Plastic Skid Plate
Fork Bleeder Valves
Rear Brake Retaining Pin
Front Axle Pull
Billet Fuel Cap
Orange Anodized Oil Filter Cover, Clutch & Front/Rear Brake Master Cylinder Cover
These models have 2010 VIN numbers
2010 KTM 530 EXC Enduro (Street Legal)
» New Frame Design
Same improvements as the 450 SX-F
Frame is welded to the steering head 10mm lower than 2009
Rotates the frame and engine forward slightly lowering the tank and seating position
Improves the weight balance, provides less deflection on the front end, better control of front wheel, lighter feeling
New lower handlebar works in conjunction with the new frame
» New Brembo Front Brake Caliper
2009 SX floating 2-piston caliper with new brake master cylinder
New TOYO B153 brake pads
Improved brake performance, less lever force, more progressive feel
» Modified Air Box With New Design TwinAir Filter
Improved air filter protection
New shape in the front to reduce dirt or water collection and a slight wall in the back to avoid water coming into the filter
New TwinAir Filter designed for the new airbox
» New Suspension Valving
PDS with new needle design
Similar needle as SX/XC from 2009 – provides damping slightly earlier for more progressive feel through the stroke
» New DID 520 VT2 T-Ring Chain instead of Regina
D.I.D.'s 520VT chain is the latest technological breakthrough in sealed chain design.
This narrow T-Ring chain is designed for Enduro racing motorcycles that can not accommodate a wider X-Ring chain due to clearance limitations.
Improved durability, less friction
8440 Lbs. Tensile Strength
» New Lighter EXCEL Rims
100 g lighter for less unsprung weight
» New Renthal Hand Grips
Dual compound, tapered design
» Engine Reinforcements and Improvements
Reinforced gear box (1,2,5,6 idler gears) for improved durability
Reworked chain adjuster & clamping rail for better tension on timing chain, noise reduction
New camshaft timing for smoother power delivery, improved rideability, optimized power band
New ignition timing for better combustion and performance
2010 KTM 530 XC-W Six Days, all above plus the following
» The 450 & 530 XC-W Six Days Edition commemorates KTMs dominance in the International Six Days Events
Limited Edition Portugal Six Days Graphics
Fork Bleeder Valves
Seat Including Race Logo and Card Holder
Machined Triple Clamps
Handlebar Protector (Bar Pad)
Front Axle Puller
Radiator Cooling Fan
Stealth Rear Sprocket - Orange
Black Fuel Tank
Hand Guards
http://www.dirtbikemagazine.com/ME2/dirmod.asp?sid=&nm=&type=news&mod=News&mid=9A02E3B96F2A415ABC72CB5F516B4C10&tier=3&nid=EF3A97F810C64882B98A68ED0CDE62FB
http://www.dirtrider.com/reviews/dirt_bike/141_0908_2010_ktm_xc_450_xcw_isde_edition_two_strokes/ktm_450_xcw_isde.html
We have plenty of off-road riding in Iowa, if you count farm fields :-). I should have moved west many years ago, not going to happen now unfortunately. Looking forward to visiting the fine state of Utah later this summer.
I guess I'm stuck with the bike nobody respects but I love it anyway. If I put the Six Days stickers on it will that help the handling?
...not sure if the KTMs have the Spec ISDE tires or not...but you don't want them!
cheers
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
