04 RM 65 need longer front break line
Wanting to raise the handlebars an inch for easier trail riding. No problem there. But, the the front break line is short. Anyone out there have an easy solution for a longer break line. Note; the similar KX 65 has a different line and routing.
You sure you need longer, on my 65 I put taller bars on an didnt need anything longer? Are you putting actual risers in or what?
YES, I had an old set of RM 80 bar caps and just flipped them over. Then used longer Gr #8 bolts. Worked well in the past and very easy to put back for track riding.
heres what I did. KLX tall handlbare, I didnt have to change a thing, the only problem is the throttle cable gets a little tight when you turn the bars all the way to the right. They are alot taller and feel alot better! Just something to look into!
