Simple question about the parts on the exhaust? (with video...)
I would post text, but you really have to watch it, otherwise it would be a bunch of pics and text, when it takes 2 minutes to talk about..
get new springs! then your pipe will be being held on better, springs get weaker over time. as well, get new o-rings onto your exhuast flang to stop the oil from leaking from your cylinder.
dude get NEW pipe.. or get that one fix.. no get a new pipe and do the above.
Yeah thats kinda what i thought, they're the original springs from 86 lol
Dude, when I have an extra $500 sittin' around I will, right now theres $0 in my bank and wallet xD Thanks for the heads up though :cheers:
where to start. from the looks of the pipe. its pulling away at the bottom most likely because the pipe and the mounts are bent or both. next there should be 2 seals on the exhaust flange. one that seals the flange to the cylinder and the another that seals the flange to the pipe. new springs wouldn't hurt ethier. if money is tight, just rtv the piss out of it until you get the money for parts.
o yea. black RVT works awesome as well!
He said money is tight. :cheers: can't get any cheaper than that right ?
all weather sillicon?...from the doller stor.
shit, i use RVT on my pipe/sillencer conection. works better then pig-tails.
Thanks for the tips, but what's rtv again??
rtv red works the same i like it cause it matches my bike.:cheers:
and where do you see $500 pipes( besides new O.E.M) for that thing your can get fmf or pc for less than 1/2 that new and around $100 used. ..might want to repack that silencer while your at it if you want to be real cheap i know a couple pro's that use steel whool to pack their silencers:thumbsup:
rtv red works the same i like it cause it matches my bike.:ride:
Thanks dude, the cheapest I could find the pipes for was a banged up stock pipe for $230... If you know of any place to find it cheaper let me know. And what do people usually use to pack them with?? Also rtv??? :cheers:
keep looking on ebay you'll find one idk about the early bikes but see if any other years fit that bike the pips might be the same
RTV silicone is a type of sealant. they come in different temps and resistances. I found that the clear rtv works the best. even on 4 stroke exhaust. almost ever parts store under the sun has it. this is what i use.
Ok cool, I probably shouldn't check my Auto Zone under that cave then. lol
:cheers: new people !:ride: glad to help.
These guys can blow out the dents, then you can hit it with high temp rattle can paint.
http://www.piperepair.com/
Otherwise ebay for a header pipe cheap! Then repack the silencer.
High temp RTV (liquid silicone gasket maker) for the pipe if it still leaks. New springs, straighten the mounts.
Stop guessing with you premix ratio, get a "ratio rite" cup. http://www.amazon.com/Ratio-Rite-Measuring-Cup/dp/B0045L9FJM
Use a quality premix oil. I like Maxima 927 http://www.bikebandit.com/maxima-castor-927-2-cycle-oil?WT.mc_id=1484958&CAWELAID=338429818
Then tune it once you have that straightened out. You should not have excessive spooge (oily residue) coming from the exhaust if you're tuned correctly. Otherwise you have other problems in the cylinder.
All these things are contributing to your problems.
Thanks for the in-depth answer, what bike are you running the premix in? Also what do you mean by tuning? And I was told by the PO that he had a fouling plug issue about 3 years ago, and "we did some adjustments in the carb and I tried all kinds of different premix ratios, and 34:1 works best". I haven't tried mixing it to anything else then that, what's your opinion?
