will a rear wheel from a 2003 cr125 fit a 2010 crf250r
need help please
i belive the wheels interchange that car back...but if you have the wheels y not just try them out? i understand if you are trying to buy a set....but look up the part number for wheel bearings for the 125 then the 250 if they are the same they fit
If the parts are the same, then the thing you need to check is the offset on the hub to make sure the sproket and disc align properly.
yes it will fit - I've don it
