help from the tall riders out there
I'm 6,2. I'm riding a 2002 rm 250. I just starting racing hare scrambles And by the end of the race i know my back and arms hurt a lot more than they should. I'm sure it has something to do with the way my bike is set up. When i stand up i feel I'm leaning way to far forward. What the best setup that you have had luck with. I was thinking some 2" risers with some sort of high bend bars. Thanks
I have under the bars scott stabalizer w/windham bend bars, I also lowered my footpesg w/fastway pegs, and a taller sdg seat. The bike is perfect for my 6'1" body. Try standing up more easier on the body.
Im 6'4 and I like my TAG bar risers and KW bars for my race bikes... of course Im standing alot and in the attack position most of the time. I dont sit much except through corners or if I need to seat bounce. Before I got the new bars and risers I got some pretty bad arm pump. But never had any back problems, maybe try bending your knees a little more so they absorb more of the impacts.
YES! Get some risers. The ones I had on my last 2 bikes moved the bars up and forward, which was fantastic. I left them on my '03 when I sold it cause the guy who bought it from me was 6'6"! There is about 3/4" of blocks under the bars on my new-to-me '07, so I'll try it for now and see.
IIRC some tall guys like CR HIGH bend bars, and Pastrana FMX bars too I think.
Some guys get Fastway LoBoy pegs too, and a tall seat foam would make things better as well, although I haven't got one yet.
Been very happy with my Rox Risers
They raise the bars 2" and you can rotate them forward or back
Don't get in the trap of using very high bars.The more bars you try the better your choice will be. Proper body position training is the key. I'm .6.6 and i use Pro Taper EVO Windham mid bars without risers.
^^^ couldnt agree more. my risers only lift the bars 1/2 inch and I also run the Windham mid bars on all my bikes and they feel perfect.
Im thinking he's keeping his legs too stiff and straight causing him to ride hunched over the bike instead of being in an attack position which naturally puts you over the front of the bike. Bending at the waist/ back instead of using your legs. Just a possibility.
its amazing tall riders can adapt to a bike like this, i am only 5,5 and yet i like RC high bend....
Let me delve into the other half of the issue that's been ignored until now....your riding an MX bike for HS racing. Has your suspension been revalved for this? If not, try dialing back your compression and seeing if the bike handles the roots and rocks better. Properly set up suspension will go along ways towards reducing rider fatigue. :cheers:
I'm 6'4" and run 10mm rise bar mounts along with Windham bend ProTaper EVOs. Seat height is stock, pegs height is stock right now, although I have experimented with low-boy (and may again some day). Just make sure your knees are bent and you are in the attack position.
As others have said, concentrate on bending your knees more. You shouldn't have your weight too far forward. Arm pump can be coming from having your levers out too far from center, let the long end of the lever do it's job. I have a SDG Tall seat on my YZ250F and it makes staying up with knees bent so much easier. I'm 6'1", no risers, ProTaper Contour on +2, and no arm pump.
I will definitely try to bend my knees more. I think part of it is just getting in shape too. I'm not used to bending my knees like that for 2+ hours. I think I'm going to go with the bar risers because i like how you can move them forward. I feel like I'm reaching back to far for the bars. I know my suspension could use some tweaking. When i hit a log in first gear my back end shoots sky high. I'm definitely going to try and move my levers in more. When I'm done racing, and some times during, my hand cramps up so bad i cant pull in the clutch. Thanks for the help guys.
also whats the advantage to the tall seat? how does it help.
It makes it easier to transition from sitting to standing.
Im 6'2 and dont run bar risers, I used to, I then rode with an extreme enduro winner and told me to take them off, he rode with David Knight and he is as tall if not taller than me and does not use them,
I find the bike corners better, and my weight is kept more over the front of the bike, as you raise your bars they go further back towards you
I see what your saying, but i almost feel as if I'm Too far over the bike. When Standing i often have to keep myself from falling forward.
Funny I was going to start a thread like this as this is how I feel too!! I am just getting back into riding after taking 15 yrs off and I am finding that my xc 300 is an awesome bike but I am 6'2" and when I stand I always feel like I am going to go right over the bars... I know I have to work on my suspension a little bit as well but I was thinking that the risers would allow me to be not so hunched over to reach the bars... mind you most of the guys that I ride with so not to because it affects the handling of the bike too much... How much does it really affect it and is it worth it to be a little more comfortable???
Hey - do you wear a kidney belt? It won't help the arms but helps keep the back pain down a little. I also have 2" risers on my bike - I'm 6'4" 250lbs and between the risers and the kidney belt I'm all good.
It was great to see this post and be reminded of my troubles last year: My back and neck hurt on my new 08 300XC. Im 6'5" and long in the body. I got bar risers, and now the pain is a memory I forgot until this post. If you are hunched over, you also arent looking as far down the trail as you should.
mog, I'm 5'7 I used to run cr high bends lol! They looked like ape hangers though.
  • Similar Content
    • By Chris Edwards
      Hey guys, I'm wondering what suspension settings you all are running front and rear?  I have a 2017 crf 250r I'm a 210lb newer rider, my settings are currently set at,
      rear suspension low speed  at 12 clicks
      rear suspension high speed 2 turns
       rebound is 12 clicks.
      Left front fork inner chamber 150psi, outer  chamber 10psi, balance pressure 150psi
      Right front fork compression position 7 clicks, rebound 29 clicks
      Sag is 4"
      Thanks guys
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at
      KEEP IT PINNED!!!!
      Alan Stillwell
    • By Jo_nathan
      Selling the showa A kit off of my yz250. It comes with a set of like new x trig adjustable triple clamps. Have 4 rides on rebuild and overall in great shape. Few dings, no dents or leaks. Setup for a 165lb a rider. Work absolutely awesome! I got hurt and cant ride for a year so I'm selling off some of my parts.
    • By Kim Franz
      lookin to upgrade my suspension on my 06 cr250, curious whats possible with some work.
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
