Advice Needed, keep it REAL please lol!
i have an 06 S with gs500 hooligan mod. i ride mostly street but take trips to the woods a few times a year also. i bought a cvk40 carb and ordered the klx needle and other parts to complete the swap (92 bucks invested in the carb so far). the bike came with an E yosh boogar welded to the stock S header (looks retarded!). My question: would i benefit ANY on stock cams and displacement by going with a new full system or should i save some money and buy an E header?
and please spare me the mrd/ssw/fcr39 or your wasting your time stuff, the bike is a toy and a cheap one at that...
It sound's to me like a good, better, best situation. Stock S header is good, E header is better, most aftermarket-larger diameter pipes are best, IMO.
...the bike is a toy and a cheap one at that...
Enough said then.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
