Jetting or Valves?
Hi All,
My son picked up a very low hour (approx 25 hours) 06 250X from a friend of mine who bought it new back in 06. Its in great shape except for the cold starting issues. Its a 49 state model with the air box lid removed and stock pipe/silencer/SA.
I rejetted it richer for the cold Idaho winter temps:
150 main
45 pilot
Has a Twin Air filter
I know these bikes can have valve issues (had an 05 CRF450R) and have not checked them yet. Yesterday I ran the battery to empty and had to then kickstart it to finally get it to run. The strange thing is that once I could get it to stay running with the choke on if I gave it any throttle at all it would die. Gradually once it would stay running longer I could get it to stay running then rode it. Also, the idle when the motor is cold with the choke on is very uneven, goes up the down and so on without touching the throttle. Had some backfiring but not excessive. Once warmed up seems to run fine and starts up fine too.
I am no expert with these 4 strokes and jetting them. Elevation here is about 2800 feet. Am I looking at a jetting issue (need to go even richer) or does this sounds more like a valve problem?
thanks Dave
Its kinda hard to say exactly what it is. Is the gas fresh? Air filter clean? No junk in the bottom of the carb has been sucked into that new 45 PJ?
Check the valves...its not hard. Follow the description in the stickly. .005" on intakes. If clearance has closed to zero or close, thats a problem that will cause hard starting.
On my son's bike, his ran ok when the valves were going, but it got harder to start and eventually wouldn't.
The hot start isn't stuck open is it? Where's the fuel screw set? Should probabably be about 1 turn to left..not more than 2.
Just a bunch of stuff to rule out. My guess is the pilot is partly plugged. Pull it out and look through it. I gave up on trying to clean mine when it got something in it and just got a new one.
my guess is the valve clearences are out of spec, same thing happened to me last spring and this spring. i shimmed them and now it starts first kick and idles smooth unlike before. also try putting new fuel in it depending on how old it is. but check the clearences. if they are out then its a 10 dollar fix if you do it yourself. if they are good then its prob carb.
Yesterday I started the bike. Started on the first kick! I am going to richen the needle one notch as there still is some bog at smaller throttle openings before the motor is fully warmed up. Fuel screw is set a 2 turns out. This bike seems to not like to start when it has sat for very long.
I'll check the valves when I richen the needle.
Thanks for all the tips,
Try this after its sat and is fully cold and you want to start it.
Turn on fuel, pull on choke, pull clutch lever and hit the starter button for a couple seconds. Stop. (this assures that there is fuel in the carb's circuits).
Twist throttle 2-3 times to WOT. Stop. (this injects fuel into the intake).
Pull clutch, don't twist throttle, and press starter. Should fire up. Might die. If dies, twist throttle to WOT 1-2 times. Stop. Pull clutch, don't twist throttle and press starter. Should start and idle. Might be rough until warms and speeds up.
Let her idle until warmed up, then turn off choke.
Ride her easy at first until fully warmed up.
Hope this helps.
Thanks Dave, I will try your procedure.
Just fyi...We were out yesterday and it was 25 degrees and snowing and my starting procedure wouldn't work. Was trying my son's bike first and I was like...***!!!! Tried mine....but my battery was weak, so it didn't last long and we had to kick it. I finally got my son's running first. Tried every sequence I could think of including holding the throttle wide open to clear it out. Nothing would work. Trick was, while pushing starter and she's close to firing off (actually it was firing a little but not enough to run) crack the throttle just a bit. I did it accidentally and she lit up!
Worked on mine too while kicking.
All the kicking warmed us up anyway!!
Thanks for all your suggestions: I checked the valves and sure enough the intakes have close up all the way, exhausts are fine. My guess is my friend we bought the bike from was not real good about air filter maint and the bike sucked enough dirt to trash the intakes. Since my son does not ride allot (probably 25 hours a year on the bike) with our weather here I am going to have a new piston/rings/OEM intakes/head work for intakes. I know stainless would be better but weighing the cost vs the amount of time my son rides this sounds like the most cost effective way to go. We will also run the stock Honda air filter from now on.
Once you do the stainless intakes, the bike is virtually indestructible. If you don't, then the clock is ticking towards the time you do the valves again.
That is such a good bike once you get it running.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
