I just joined here, and I looked at the sticky but I have some questions.
From what I can tell, the stock carb sucks. Everyone is "jetting" or getting new jets. What does this mean?
What is the 3x3?
I've heard people say that they re-jet and do the 3x3 and it makes a hell of a difference. Is there a writeup? what is this? is it a kit?
Thanks lol
Try doing a 3x3 search, lots of info. Then ask away. There are guys and gals on here that are really GREAT help.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
