mean bog on 00 cr 125
i have out a new cylinder and piston kit in it and cleaned the carb and it still has a mean bog from idle. its the same jetting i have ran fro years and it worked great but it just wants to bog at low rpms and im not talking about normal 125 bog its bad. could this mean i need to check the reeds.
stock jetting
needle second clip
v-force reeds
air screw at 1 1/2 turns out
Edited by cory D
i found the problem
the reed on the uper left thought it was a good idea to try ad go sideways and twisty like
So you put a new cylinder and piston in it, didnt inspect the reeds? did you even do the power valves?
If you are going to do the job, do it right and complete the first time.
