Do I need new blinker with this mod?
I am about to order the Edge Tail Light Holder Kit which comes with blinker stays. Will I be able to mount the stock blinkers with this kit. The reason I am asking they also sell the edge blinker stay which says that it allows you to use the stock blinker. Why would they sell it separately if it comes with the kit. Sorry if this sounds dump just trying to make sure so I don't have to pay $20 to ship a $8 part.
Thanks a bunch.
I have stock blinkers with the non-specific DR-Z stays. They mount up just fine.
i just bought the "kit". it came in a paper shipping envelope. i also paid 6.00 to get the
"special" adapters for the stock blinkers. they are 2x2 l brackets with two holes in them. i could have found and made them myself, after some trial and error. i guess my time is worth something. the ease of install was due to having every possible part needed to get her done.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
