crank bearings
need to replace crank bearings and seals in my 73 sc500 yamaha.wanted to know where to get them at a reasonable price.thank you
If you have them out, take them to a bearing supply type outfit. Tell them what it is going to be used in. Usually a C2 bearing type will work. It should be a little less than a dealer. They might even have the same brand. They should have seals too. Koyo or something like that?
