Cr 125/250/500 70 watts at idle please read
Hey guys I just made a 70 watt electrical system at IDLE!!!! for a CR250 1997-2001!!! I need help guys i want to see if i can make elcetrical systems of the same caliper for the CR 125/250/500 I have seen my friends 1992 CR250 the stator was the same and the flywheel was the same as my 2001 CR250 the timing feature was a little different. (but that is easy to modify, i have access to a 3 axis cnc). It seems i can easily make a stator and flywheel kit for a 1987 or 88 through 2007. And what i have researched from parts fisches and friends bike this electrical system kit can be easily adapted to CR 125/500 if people have any pics or info. please respond!!!!!! If you want this electrical system i have the connection through Trail Tech to make it happen!!!!!! For me it is about R&D. The flywheel i made adds 9 oz. over stock weight. The Torque, and stability of the bike in extreme conditions is amazing!!!! Plus you add the 70 watts so right now on my 01 CR250 i have a Trail Tech X2 HID racelight and there Voyager GPS computer!!!!! The best thing ever when it comes to newbies on a trail!!!! I am serious!!! a breadcrump feature you have to experience for your self, and an easily adaptable bar adapter that is beefy!!!!! not a wimpy mount at all. Please see my post about the 2001 CR250 mod that you need to read. If anybody can respond with information or interest, that would be great!!!!!!!!
Any body want to go night riding??? Ha Ha I'll be at the bend ISDE c u there
How much does this cost? I have a 1997 CR125, and right now I have lights running off of batteries. I'm interested in having a lighting stator in my quest to make the bike street legal here in Ohio.
The stator would be anywhere from 80 to 90 dollars, but the thing is i need to elongate the hookup wires!!!!! The other thing is i need to modify your OEM backing plate so the stator won't ground out. If your interested let me know it should only take an hour or so, and i'll charge you only $20 to do it if you want. The flywheel is a different story, that would be alot more. But it's worth it the 70 Watts at idle is pretty sweet.
backing plate=$20
flywheel=? (a lot more)
shipping everything= $30 give or take
So I'm up to $150 plus the flywheel. About how much would it be for the flywheel? What has to be done to it? Will my stock fw work?
I'm at work until about 7 Pacific standard time i will respond further, its alot to explain!!!
Is there anyway you can post a picture of the stator in your 125? If i see a pic of the stator i can make sure 100% that i can make the stator and flywheel combo. I would hate to have you ship me all the stuff and have me not be able to do anything. I have done it for my 250, and i heard that the 125's and 500's electrical system are the same!!! but you can't always believe what you are told. The flywheel is the only hard part for me because i am machining it all own my own, and the bore where you adapt the spindle is very crucial to meet the tolerance so it takes about four and a half to five hours to machine. Then i build it up all in all it's about a 5 to six hour job. I can get all the parts for about 90 dollars i would want at least 60 dollars to machine it, and build it up. The only thing is after i am done building it up you have to get it balanced by Trail Tech, and there flywheel balancing machine which is another 20 dollars so the flywheel would be $170. I would need your OEM flywheel for the timing positioning for the flywheel. So you would have to send me your OEM flywheel and stator, and the OEM flywheel won't come back because i would need to use the spindle out of it. If your still interested post back and i will reply, tomorrow i am working on my dirt bike tonight and getting it ready for our outdoor motocross season in Portland, Oregon. It's the longest running thursday night motocross in the US, and the season opener is this thursday. Thanks, and hope to hear back from you!!!!!!
So around $300? That doesn't sound too bad actually considering that I know of no other person offering this for older bikes. Is there any way to shave off some of the added weight? I don't think the added fww would be a good thing on my 125.
Do you need pics of the stator off, or can I just pull the cover off and take a pic?
I've been looking for something like this for my 2000 CR250. Definitely interested. :cheers:
I recently found this post and sent a pm to that guy to inquire but I don't think he is active on that site any more:
Anyway, here are his pictures of his 200W stator setup for a '99:
Edited by Nummie
Wow. That guy is dedicated who made the 200 watt electrical system. He has to be a mechanical engineer or something of that caliper to do a 3D cad drawing then intergrated it into a 3D cam program. Nummie I know i can make an electrical system no problem for you 250, if you are interested. Fletchman I still do want to see a pic of your stator just to make sure. Nummie i posted all the pricing and info. if you want the electrical conversion. I am racing tonight at PIR. It's our local motocross race series. I won't be able to post back tonight, but i will first thing tomorrow mourning. Thanks
I can remove the added weight no problem, You can take a pic of the stator right in the bike if you want.
Does the trail tech stuff just work on newer digital systems? 97 and up for CR250's, not sure what year 125's switched over.
Is trail tech stuff reliable?
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
