CA woods YZ125
Last summer I found this 2002 YZ125 with the nubs still on the stock tires:
The original owner bought it for his grandson, who rode it up and down the street a few times.
I added:
Standard enduro armor and break-away levers
EG 144cc top end with broad powerband porting
Keihin PWK 36mm
7oz FWW
18" rear with tubliss front and rear
Coolant overflow tank, 1.125 bar w/ risers, etc.
Next up is a tall seat, suspension work and maybe a damper.
This bike is incredible fun! My orange 300 may see lots of garage time this summer...
nice find man!
how is the eric gorr 144cc big borr kit! how do it run and do it run hot alot, and how many times have u change the piston
and wats a 7oz FWW
How do you like the 7oz weight in regards to the power band?
I put the 7oz freewheel weight on at the same time as the EG 144, so I can't really say how one performs without the other. I may remove the 7oz just to see what it feels like without it.
There's plenty of power, even for technical uphills (I weigh 175lbs). I've had to feather the clutch to maintain RPMs much less than before the 144.
As for rebuilds - I'm not flogging the 144 motor anywhere near as much as the 125, so I should get more time out of each top end.
Nice find man! I like it!
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
