Water in motor, Help please!
Alright so i was replacing my top end and while waiting on the new piston/rings etc. .There happen to be a whole in the garage where i had my bike. My top end was off and i had a rag covering up my bottom end. When I went to the garage this morning it was full of water. It was fairly clean water i soaked up as much as i could. Drained out all the oil and most of the water, put some new oil to make sure it was still lubricated as much as possible. .Im not very mechanically inclined so im wondering if there is something else i should do or if it will cause any damage. Its an 03 kx 125 (2 stroke) I'll appreciate any pointers you can offer thanks !
Well... all i know if when i dropped my celly in the lake, i put it in a bag of rice and it removed all the moisture :cheers:
Id drain oil, change it. Run motor and change it again.
I don't know how this will react to the rubber seals, but maybe rinsing it out with wd-40 isn't that what it was originaly ment for. Like i said not sure about the seals hopefully some one else knows more and chimes in here.
You need to get the moisture out before it attacks the bearing surfaces.
I had a plug rattle out on a 144 and it was a mud race and the bike was COVERED. Just seemed like it was blown up and i couldnt see anything other then mud under the cylinder so i started blasting it off that night and once it was somewhat cleaned up realized it was the plug just sitting on top of the head. Pulled the head and cylinder and mud and water were all over the dome of the piston and in crank. What i did was took the motor out of the frame, and flushed the bottom end out with wd-40 like ten times, after each rinse blowing it dry with an air compressor (having friend hold bottom end upside down). Threw it back int he frame, gave it a few squirts of wd-40 and put it back together with a new top end after giving the cylinder and head a good cleaning, ran like new. The oil wont see any of that water if the water only went down into the crank case, the tranny oil is sealed from the crank case. Only way water would of mixed with it would be if you had a bad main seal on the right side...
Take off the fuel tank and carburetor and turn the bike upside down.
If you are willing, take the engine out and try to blow it out with air, then go to Wal-Mart and buy some of the cheapest motor oil they have. Start rinsing it out with the motor oil a few times, then switch to rinsing it out with premix.
Spin the crankshaft around to check for rusted bearings on the crankshaft. If they are rusted, your engine is in bad shape.
^^^^this is how we do it when a bike gets drowned here on the wetside of washington.
after turning the bike upside down put the bike into 3rd or higher gear and spin the rear wheel both directions. since you have the jug removed you'll want someone to hold the rod in the center so it doesn't get all dinged up from flopping around and he can tell you when it stops spraying water out of the crank.
check the bearings with a light and mirror like kdx said to verify that rust hasn't gotten a foothold. reassemble as soon as possible and introduce some seafoam into your premix and this will help with any residual water vapor that is left over.
it's key to do this as soon as possible as the rust will start in as little as 48 hours.
changing the oil won't help at all as the trans is sealed off from the cylinder/crank area.
now, hurry up!
Well it looks like he did manage to catch it inless then 24 hours and he drained it and dumped some new oil into it he may have saved it himself.....
WD-40 would have worked. The WD stands for "Water Displacement" anyway, that's what it was meant for.
wd40 and other spray oils displace water,read the can.Then run it,heat will turn water to vapor and that will leave with your exhaust.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
